patch for Linux support
Here is a quick patch to get Arduino working smoothly on standard Linux installs. Basically, it makes Arduino find the avr-* tools in the path if its not on Mac OS X or Windows. Its tested on a Mac and on a Debian machine. Apply by running this in Arduino code in trunk/app:
patch -p0 < linux_support-2006-08-26.patch
http://idmi.poly.edu/pdlab/linux_support-2006-08-26.patch
Wonderful. Thank you. I'll apply this and it should be in Arduino 0005 (due RSN).
I have the Arduino 0005 alpha and I'm still getting path problems. How do you apply this patch? I'm a bit clueless.
I would try 0006, this patch is included. So if that doesn't work for you, then there is another problem which should be fixed.
