Path Memorisation Failing Elegoo Smart Car
Hello, I am experimenting with the Elegoo Smart Car 4.0 and I want to be able to record button presses (so which button and the duration untill next button press), memorise its path, and with another button execute it's path. While it drives fine, it doesn't seem to even start recording as none of my messages seem to show up on the serial motor (but the hex codes do) is there any way to improve this code?
#include <IRremote.h>
// Motor driver pin configuration
#define PWMA 5    // Controls power to right motor
#define PWMB 6    // Controls power to left motor
#define AIN 7     // Controls direction of right motor, HIGH = FORWARD, LOW = REVERSE
#define BIN 8     // Controls direction of right motor, HIGH = FORWARD, LOW = REVERSE
#define STBY 3    // Place H-Bridge in standby if LOW, Run if HIGH
// #define resetPin A0
int path[50]; // Store path as an array
int pathIndex = 0; // Index to keep track of the current step in the path
bool recording = false; // Indicates whether we are recording a path
// IR remote setup
int RECV_PIN = 9;  // IR receiver pin
IRrecv irrecv(RECV_PIN);
decode_results results;
  // Motor pins setup
  pinMode(PWMA, OUTPUT);     //set IO pin mode OUTPUT
  pinMode(PWMB, OUTPUT);
  pinMode(BIN, OUTPUT);
  pinMode(AIN, OUTPUT);
  pinMode(STBY, OUTPUT);
  digitalWrite(STBY, HIGH);  //Enable Motors to run
  digitalWrite(PWMA, LOW);  // Fully on
 // digitalWrite(PWMA, HIGH);  // Fully on
  // Start the IR receiver
  irrecv.enableIRIn();
  if (irrecv.decode(&results)) {
    int value = results.value;
    // Print the received IR code to the serial monitor
    Serial.println(results.value, HEX);
     // Handle the IR remote buttons
     if (value == 0xFF6897) {
      if (!recording) {
        // Start recording
        recording = true;
        pathIndex = 0;
        Serial.println("Recording started.");
      // Stop recording
      recording = false;
      Serial.println("Recording stopped.");
    delay(500); // Debounce the button
  if (recording && pathIndex < 50) {
      // Store the received IR code in the recorded path
      path[pathIndex] = value;
      pathIndex++;
      Serial.print("Recorded");
      Serial.println(value, HEX);
      delay(500); // Delay to prevent recording multiple actions in one press
if (value == 0xFF9867) { // Replace with your playback button code
      Serial.println("Playback started.");
      executePath();
      switch (results.value) {
      case 0xFF629D:  // Forward
        moveForward();
      case 0xFFA857:  // Backward
        moveBackward();
      case 0xFF22DD:  // Left
        turnLeft();
      case 0xFFC23D:  // Right
        turnRight();
      case 0xFF02FD:  // Stop
        stopCar();
      default:
        // Unknown code; do nothing
 irrecv.resume(); // Receive the next value
// Functions to store and recall path
void executePath() {
  for (int i = 0; i < pathIndex; i++) {
    int value = path[i];
    switch (value) {
      case 0xFF629D:
        moveForward();
      case 0xFFA857:
        moveBackward();
      case 0xFF22DD:
        turnLeft();
      case 0xFFC23D:
        turnRight();
      case 0xFF02FD:
        stopCar();
      default:
        // Handle unknown path steps
    delay(1000); // Delay between transmissions (adjust as needed)
// Functions to control the car's movement
void moveForward() {
 digitalWrite(AIN, HIGH);    // Forward direction
 analogWrite(PWMA, 120);   // Full power
 digitalWrite(BIN, HIGH);    // Forward direction
 analogWrite(PWMB, 120);   // Full power
void moveBackward() {
  digitalWrite(AIN, LOW);    // Backwards direction
  digitalWrite(BIN, LOW);    // Backwards direction
void turnLeft() {
  digitalWrite(AIN, HIGH);     // Backwards direction
  analogWrite(PWMA, 60);   // Full power
  digitalWrite(PWMB, LOW);
void turnRight() {
  digitalWrite(PWMA, LOW);   // No power on Right
  analogWrite(PWMB, 60);   // Full power
void stopCar() {
  digitalWrite(PWMB, LOW);   // No power on Left
/* void resetArduino() {
  pinMode(resetPin, OUTPUT);
  digitalWrite(resetPin, HIGH);
Perhaps putting more debug information in the serial.Print() messages.
an int is a 16 but quantity capable of holding -32768..32767 so there is no way it will ever match a large value like 0xFF6897. If you look at the examples that come with the IRremote library, you will notice the return value is of type unsigned long
thanks! its now at least showing the recording messages so I can work further on making it actually ride its memorised route
Update: I changed a couple of more int to unsigned long and now it works completely!
