path of a mysql table
Hi!
populate a mysql table is it possible to know its path and eventually put it in SD card?
Hi Giuseppe
I'm not sure I understood your question...you can of course install MySQL on Linino and change the "datadir" property to a folder on your SD card...
for example following this guide from OpenWRT wiki:
http://wiki.openwrt.org/doc/howto/lamp#installing.and.configuring.a.database.server
thanks luca for your answer, you understand me!
so I need to re-install mysql and change the "datadir".
i think you have not to reinstall
i call my database with php on this way
$db=new SQLite3("/www/sd/Aqarium/Aquarium.db");
so i can store the db on sd card
Otto, you're using SQLLite while giuseppe is using a different DBMS, MySQL...
Giuseppe, you may try to:
  • stop mysql daemon
  • create the new datadir on your SD card
  • (optional) move the existing data
  • change the configuration
  • restart
http://crashmag.net/change-the-default-mysql-data-directory-with-selinux-enabled
trying without effect to change the configuration,
I have decided to re-install mysql for change the datadir
many many thanks for YOUR help
you're welcome!
