I got some issue here.. I am using a continuous servo and wanted to stop/pause at certain angle, but I couldn't manage to find a correct program to do it. Right now, after it reach the wanted angle it will just instantly return to starting point. Is there any code/program to pause it or solve this issue ?
Thanks.
Hi and welcome.
Continuous servo means you have disabled the potentiometer inside it.
That means you have no feedback of the angle reached.
How do you know you have reached the desired angle ?
I haven't done anything with continuous servos yet, if i understood correctly, you send the servo to go to 90 degrees to stop moving.
If you want it to move, you send it to 0 or 180 degrees for high speed, and the lower the value, the lower the speed.
So setting an angle of 100 would have it move relatively slow.
danielphua:
You show me yours and I will show you mine
Post your code so we can understand your problem.
...R
