Pause problem. cant undo and repeat
I need to pause my loop and when i press the same button my loop need to continue where it was. But now when i press pause i cant undo it. Any idea on how to fix it?
My Code:
#define MotorBewegenLinks 7
#define MotorBewegenRechts 8
#define Punt1 4
#define Punt2 5
#define Punt3 6
#define Start 10
#define Stop 2
#define Noodstop 3
#define Sensor 9
#define Herstel 11
#define bakopen 12
#define bakdicht 13
int stap = 0;
int status_pauze = 0;
bool edge = 1;
    pinMode(Punt1, OUTPUT);
    pinMode(Punt2, OUTPUT);
    pinMode(Punt3, OUTPUT);
    pinMode(MotorBewegenLinks, OUTPUT);
    pinMode(MotorBewegenRechts, OUTPUT);
    pinMode(Start, INPUT);
    pinMode(Stop, INPUT);
    pinMode(Noodstop, INPUT);
    pinMode(Sensor, INPUT);
    pinMode(Herstel, INPUT);
    pinMode(bakopen, OUTPUT);
    pinMode(bakdicht, OUTPUT);
    attachInterrupt(digitalPinToInterrupt(Stop), Pauze, RISING);
    attachInterrupt(digitalPinToInterrupt(Noodstop), noodstop, RISING);
  if(digitalRead(Start) && digitalRead(Sensor)){
      stap = 1;
     for(int i = Punt1; i <= Punt3; i++){
      water(i);
void water(int punt){
  digitalWrite(MotorBewegenLinks, HIGH);
  Serial.println("Motor links aan");
  digitalWrite(MotorBewegenLinks, LOW);
  Serial.println("Motor links uit");
  digitalWrite(punt, HIGH);
  Serial.println("Aangekomen bij punt");
  digitalWrite(bakopen, HIGH);
  Serial.println("Bak open");
  digitalWrite(bakopen, LOW);
  digitalWrite(bakdicht, HIGH);
  Serial.println("Bak dicht");
  digitalWrite(bakdicht, LOW);
  digitalWrite(punt, LOW);
  Serial.println("Weg bij punt");
  if ( punt == Punt3){
    digitalWrite(MotorBewegenRechts, HIGH);
    Serial.println("Motor terug naar begin");
    delay(3000);
    digitalWrite(MotorBewegenRechts, LOW);
    Serial.println("Motor bij begin");
void Pauze(){
 edge = 1;
 status_pauze = !status_pauze;
 while (status_pauze = 1){
 if (digitalRead(Stop) && edge == 0){break;}
 Serial.println("Pauze hoog");
 if (digitalRead(Stop) == 0){
  Serial.println("Pauze uit");
    edge = 0;
This is a problem but there may be others
You should not be calling loop () explicitly like this.
You should not have blocking code in interrupt context
that wasnt supposed to be there i removed it. as in i first need to have a working pause before adding a noodstop
Please post your code as it is now in a new reply here
i edited the post the code as it is now should be there
That was not what I asked you to do
What I asked was
Now, of course, comments on the original code are meaningless and you have not fixed the problem that I pointed out anyway
I dont understand sorry
You posted a sketch
Comments were made about the sketch
You say that you changed the sketch
The comments no longer make sense
The code in your original post still has at least one problem
= is used to assign a value to a variable
== is used to compare 2 variables or values
As it is, that line of code sets status_pauze to a value of 1. It does not compare it with a value of 1
You didn't declare the function 'noodstop' you call when the Noodstop pin rises.
sketch_jan06b.ino: In function 'void setup()':
sketch_jan06b:37:52: error: 'noodstop' was not declared in this scope
Ty this worked
