This is my first Arduino project using a Mega and TFT. While waiting for the hardware to arrive, I coded five pages and the touchpad. I used delays to simulate the hardware to confirm my flow. Now I am trying to add the hardware. I would like the SecondPage() to pause and wait for a button press, beep and then advance to the ThirdPage().
I tried to activate the interrupt during the delay(1000), but the delay just pauses and then continues to 1000 before advancing to the ThirdPage(). I need a variable delay to compensate for the different elapsed times before the button is pressed, ie someone might take longer than 1000.
Then I tried “while” with changing a flag, creditcardState, when the increment() is used. When the switch is closed, the buzzer beeps but the program does not advance to the ThirdPage(). I also tried “while” with (digitalRead(buzzerPin)) with the same results.
I would appreciate any help to point me in the right direction. The program is 82412 bytes, so I have just included the sections I thought appropriate.
#include <UTFT.h>
#include <URTouch.h>
#include <Servo.h> //use pin 9
int x, y, z = 0;
char Pass[5] = "";
char master[5] = "6187";
int Pcount = 0;
int PassCounter = 0;
char Last[5] = "";
int pos = 0; // variable to store the servo position
Servo myservo; // create servo object to control a servo
int buzzerPin = 11;
const int creditcardPin = 21;
int creditcardState = 0;
unsigned long button_time = 0;
unsigned long last_button_time = 0;
//Page 1
void FirstPage()
myGLCD.clrScr();
myGLCD.setBackColor(0, 0, 0); // Sets the background color of the area where the text will be printed to black
myGLCD.setColor(255, 255, 255); // Sets color to white
myGLCD.drawBitmap(70, 10, 180, 90, camera); // Prints the security camera jpeg
myGLCD.setFont(BigFont); // Sets font to big
myGLCD.print("If you need to reset", LEFT, 130); // Prints the string on the screen
myGLCD.print("/ reboot the program,", LEFT, 154); // Prints the string on the screen
myGLCD.print("remove the battery.", LEFT, 178); // Prints the string on the screen
myGLCD.print("Thank You.", CENTER, 202); // Prints the string on the screen
myGLCD.setColor(0, 255, 0); // Sets color to green
for (int L = 23; L <= 341;)
myGLCD.fillRect(0, 228, L, 230);
delay (1000); //wait 15 seconds
L = L + 10;
myGLCD.clrScr();
//Page 2
void SecondPage()
myGLCD.setColor(255, 255, 0); // Sets color to yellow
myGLCD.print("W B and J Bank", CENTER, 10); // Prints the string on the screen
myGLCD.print("South Wales, NY", CENTER, 34); // Prints the string on the screen
myGLCD.setColor(255, 0, 0); // Sets color to red
myGLCD.fillRect(0, 54, 319, 56);
myGLCD.print("Welcome", CENTER, 60); // Prints the string on the screen
myGLCD.print("To begin, please", LEFT, 84); // Prints the string on the screen
myGLCD.print("insert and quickly", LEFT, 108); // Prints the string on the screen
myGLCD.print("withdraw your card.", LEFT, 132); // Prints the string on the screen
myGLCD.print("The next menu will", LEFT, 156); // Prints the string on the screen
myGLCD.print("then display.", LEFT, 180); // Prints the string on the screen
myGLCD.drawBitmap(64, 204, 191, 30, images3); // Prints the credit card jpeg
//delay(10000); //interrupt just beeps and pauses delay, advance to ThirdPage at end of delay. Delay needs to be variable not fixed.
//while (creditcardState == 0) //wait for button press;interrupt just beeps, no advance to ThirdPage
while (digitalRead(buzzerPin == LOW)) //interrupt just beeps, no advance to ThirdPage
//do nothing
//Page 3
void ThirdPage()
// Initial setup
myGLCD.InitLCD();
myGLCD.clrScr();
myTouch.InitTouch();
myTouch.setPrecision(PREC_HI);
myGLCD.setBackColor(0, 0, 255);
myservo.attach(9); // attaches the servo on pin 9 to the servo object
attachInterrupt(digitalPinToInterrupt(21), increment, FALLING); //TFT stops working
pinMode (creditcardPin, INPUT);
digitalWrite(creditcardPin, HIGH);
pinMode(buzzerPin, OUTPUT);
FirstPage();
SecondPage();
ThirdPage();
FourthPage();
drawButtons();
void increment() //debounce and sound goodbuzzer when switch is pressed
button_time = millis(); //check to see if increment() was called in the last 250 milliseconds
if (button_time - last_button_time > 250)
z++;
goodbuzzer();
creditcardState = 1;
Serial.println(creditcardState);
last_button_time = button_time;
void loop()//reads touchpad buttons, compares entry to master value, if match displays the FifthPage and activate the servo
