pause sketch
I'm using a Parallax u-sound sensor to sense distance. I have 6 LEDs that light in sequence as the object gets closer, then they flash once all are lit. After the LEDs are all lit, I have them flash a set number of times and then turn off. I don't want them to sit there and flash forever. I have all of that working. I want to continue to monitor the sensor though. So if the object moves away and comes back, the sequence will begin again. I have tried do-while, for-else, if, etc.
If it's not obvious, we're in noob territory here. Be gentle with me.
for-else
Maybe you need an if loop.
What you really need to do is post your code.
int duration;
int sensor = 7; //pin 7 will pulse to initiate measurement, then will be read to determine distance
int pin1 = 3;
int pin2 = 5;
int pin3 = 6;
int pin4 = 9;
int pin5 = 10;
int pin6 = 11;
int pulsewidth = 255;
pinMode(3, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(sensor, OUTPUT); //set pin 7 to an output
digitalWrite(sensor, LOW); //clear sensor pin
delayMicroseconds(2);
digitalWrite(sensor, HIGH); //ping sensor pin
delayMicroseconds(5);
digitalWrite(sensor, LOW); //stop ping
pinMode(sensor, INPUT); //change sensor pin to input
duration = pulseIn(sensor, HIGH); //read sensor duration
Serial.println (duration);
if (duration <= 2000) analogWrite(pin1, pulsewidth); //turn LEDs on if distance is small
if (duration <= 1600) analogWrite(pin2, pulsewidth);
if (duration <= 1100) analogWrite(pin3, pulsewidth);
if (duration <= 800) analogWrite(pin4, pulsewidth);
if (duration <= 500) analogWrite(pin5, pulsewidth);
if (duration <= 300) analogWrite(pin6, pulsewidth);
delay (100);
if (duration <= 300) analogWrite(pin1, LOW); //turn LEDs off for flash function
if (duration <= 300) analogWrite(pin2, LOW);
if (duration <= 300) analogWrite(pin3, LOW);
if (duration <= 300) analogWrite(pin4, LOW);
if (duration <= 300) analogWrite(pin5, LOW);
if (duration <= 300) analogWrite(pin6, LOW);
delay (100);
if (duration > 2000) analogWrite(pin1, LOW); //turn LEDs off if distance is large
if (duration > 2000) analogWrite(pin2, LOW);
if (duration > 2000) analogWrite(pin3, LOW);
if (duration > 2000) analogWrite(pin4, LOW);
if (duration > 2000) analogWrite(pin5, LOW);
if (duration > 2000) analogWrite(pin6, LOW);
delay (100);
:roll_eyes:
When posting your code, make sure to wrap it in [code ] tags by highlighting it and pressing the # mark.
while(testCondition) ; //Semicolon just means do nothing. This would work, too:
//while(testCondition) {}
testCondition would be anything that returns a TRUE or FALSE. It could be a digitalRead, like so:
while(digitalRead(4));
or a compare
while ( analogRead (2) < 531 ) ;
or anything else really. Make sure that you remember that if you do something like this:
while ( val < 531 ) ;
val won’t get updated and will either pass through immediately or never. This would work though:
while (val < 531) {
  val = analogRead(5);
Why are you performing 6 evaluations of a value that can’t change between evaluations?
Of course, the use of arrays would shorten this.
You are using PWM pins to turn the LEDs ON or OFF. What a waste…
Thanks for the advice.
The reason I’m doing 6 evaluations of a value that can’t change is because I don’t know what I’m doing. Still learning…
I don't know what I'm doing.
Using PWM pins is covered in chapter 8. Using digitalWrite() to turn a pin on or off is covered in chapter 1. What chapter are you on?
chapter of what? :~
