I am trying to get 1 stepper motor to sweep back and forth.
Once my camera sees a barcode, the stepper motor will pause for 3 seconds. The stepper motor will continue the sweep from exactly where is stopped. (This is what I want)
I put the IF statement before the For. The sweep does stop when seeing a barcode but only after a full sweep. Not mid sweep. This is the code for that. Closest I got to it working. (code edited)
// Stepper Motor X
const int stepPin = 2; //X.STEP
const int dirPin = 5; // X.DIR
#include <Pixy2.h>
Pixy2 pixy;
// Sets the two pins as Outputs
pinMode(stepPin,OUTPUT);
pinMode(dirPin,OUTPUT);
Serial.print("Starting...\n");
pixy.init();
// change to the line_tracking program. Note, changeProg can use partial strings, so for example,
// you can change to the line_tracking program by calling changeProg("line") instead of the whole
// string changeProg("line_tracking")
Serial.println(pixy.changeProg("line"));
int8_t i;
char buf[128];
pixy.line.getMainFeatures();
digitalWrite(dirPin,HIGH); // Enables the motor to move in a particular direction
// Makes 600 pulses for making one full cycle rotation
if (pixy.line.barcodes->m_code==0){ // camera sees a barcode
Serial.println("zero"); // print zero
delay(3000); // wait 3 seconds
return;
for(int x = 0; x < 600; x++) {
digitalWrite(stepPin,HIGH);
delayMicroseconds(150);
digitalWrite(stepPin,LOW);
digitalWrite(dirPin,LOW); //Changes the rotations direction
// Makes 600 pulses for making two full cycle rotation
return;
It Is always worrying when an instruction and a comment say different things.
Do you want to pause for one second, like the comment.
Or do you want to pause for 0.2 of a second like the instruction will?
That is not what the break instruction does. There is no single instruction to do what you want to do.
I don't think you want to use break because that ends the for loop, which means the value x is lost, so the loop cannot continue from where it was paused. This may result in it moving too far in either direction and hitting any "gimbal" limits you may have (physical limits of where the motor can move to). That might be causing the shaking you described.
I think this is close to what you want. After every step, check the camera to see if it is seeing any barcode features.
// Stepper Motor X
#include <Pixy2.h>
Pixy2 pixy;
pinMode(stepPin, OUTPUT);
pinMode(dirPin, OUTPUT);
pixy.init();
void sweep()
for (int x = 0; x < 600; x++)
// Take one step.
digitalWrite(stepPin, HIGH);
digitalWrite(stepPin, LOW);
// Check for a barcode.
if (pixy.line.barcodes) // camera sees a barcode
pixy.line.barcodes->print(); // print barcodes
digitalWrite(dirPin, HIGH); // Enables the motor to move in a particular direction
sweep();
digitalWrite(dirPin, LOW); //Changes the rotations direction
sweep();
It takes time to analyze a picture, looking for barcodes. You may want to check the image only every 6, 10, 20, 30, or 60 steps. That will give less position resolution but will speed up the sweep quite a bit.
Adding delays is not going to make the sweep faster.
const int STEPS_PER_FRAME = 10; // 600/10 (60) frames per sweep
void sweep()
// Take one step.
if (x % STEPS_PER_FRAME == 0)
I also put the If (camera) command first, then the for (stepper motor) second in the void sweep ().
Thanks a lot! You did 99% of it.
edit: false alarm: stepper only stops at end of sweep.
[code]
// Stepper Motor X
#include <Pixy2.h>
Pixy2 pixy;
pixy.init();
void sweep()
// Take one step.
sweep();
sweep();
[/code]
It looks to me as though you check for a barcode once then make 600 steps so the camera only ever looks for a barcode at the ends of the sweep range. Is that really what you want to do ? I thought that the idea was to look all around for a barcode
Still tweaking it. Stepper motor runs for 100 steps before checking the camera. This repeats 6 times (total 600 steps) before changing direction.
If I check camera every step, the stepper motor gets jittery so I am compromising by checking camera every 100 steps.
[code]
// Stepper Motor X
#include <Pixy2.h>
Pixy2 pixy;
pixy.init();
void sweep()
for (int y = 0; y < 6; y++) // number of times to run x before changing direction
for (int x = 0; x < 100; x++) //check the camera every 100 steps.
// Take one step.
delayMicroseconds(200); // stepper doesn't run without these delays.
sweep();
sweep();
[/code]
