I am completely new to using Arduino and don't have the time to figure out coding for this project. I've found things that are similar and messed around with a few things but haven't been able to figure it out and don't have the time to really figure it all out. So I am needing some help with writing the sketch and creating a wiring diagram/schematic for the following project.
I will provide a description of the project as well as a list with links to the various components I have for this. I will also provide a link to a video of a similar project so you can get a better idea of what it will look like/what the functionality should be.
Here is a project description:
I've built a desk that contains a monitor lift/sled that moves my computer monitors up and down so that I can conceal them when I'm done using them. I want to be able to press a button and have the motors attached to the sled turn on to move the monitors up and down and then I'd also like a sound to play when the monitors move UP. A more detailed description of the steps I'm looking for:
With the first press of the button, the motors will turn on and the sled will begin moving up. The motors will shut off and remain in place once they come in contact with an upper proximity switch. When pressing the button this first time, a sound will also play from an SD module through a small speaker. The sound playing and the motors starting will happen simultaneously.
Once I hit the button a second time, the motors will start again in reverse, moving the sled back down. Once again, the motors will stop once the sled makes contact with a lower limit proximity switch.
Finally, the push button I purchased is an LED push button and I'd like the LED light to remain on at all times even when the motors are off.
Some more project notes:
I purchased a sabertooth dual 12A motor driver to control the motors. I purchased a large power supply that will be connected to the sabertooth but I would also like this to power the Ardunio as it has multiple connections. I will attach the link to the power supply I purchased below.
Link to a video showing what this will look like once it's completed: DIY Schreibtisch mit dualem Monitor Lift - Bauanleitung | Tips, Tricks & More - YouTube
Here is a list of the specific components I have already purchased for the project:
Arduino Mega2560
Power Supply: eTopxizu 12v 30a Dc Universal Regulated Switching Power Supply 360w for CCTV, Radio, Computer Project
Sabertooth Dual 12A Motor Driver
2 of these motors: BEMONOC Garage Door Motor 12V DC Right Angle Reversible Electric Gear Motor 45 RPM High Torque
2 of these Proximity switches: https://www.amazon.com/gp/product/B0872Y3C7D/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
SD Card Module: SunFounder SD Card Module Slot Socket Reader
Speaker: MakerHawk 2pcs Speaker 3 Watt 8 Ohm Single Cavity Mini Speaker
I'm new to using this forum when it comes to wanting to hire/pay someone so I will just start here and go from there.
Thanks in advance!
