Payload: Arduino - The Things Network (Arduino MKR WAN 1310)
Hi all :slight_smile: ,
first of all greetings to all. I am new to the community, and this is the first post I am writing.
After searching many hours on the internet and on the forum, I have not found the information I need, so I decided to write this post.
I have made my first connection to The Things Network using the following tutorial:
Connecting MKR WAN 1300 to The Things Network (TTN)
With this example, the variable "payload" is created and sent to TTN. So far so good.
int var1 = 10;
byte payload = var1;
My problem arises when I want to send two variables in a single message. How can I send two variables in a single message?
For example:
int var1 = 10;
int var2 = 20;
Thank you very much in advance for your help.
Best regards
post your full code.
basically what is sent to the LoRaModem instance in between the modem.beginPacket(); and modem.endPacket(true); will make it to the other side.
for future post, do yourself a favour and please read How to get the best out of this forum and post accordingly (including code tags and necessary documentation of your ask).
