Pb Timer
hi there
if someone can help me to debug my pb on the timer because its working only till 32" but not more
thx
this is the programme:
#include <IRremote.h>
int RECV_PIN = 11;  // récepteur IR à la pin 11
IRrecv irrecv(RECV_PIN);
decode_results results;
int LED_1=2;
int LED_2=3;
int etatRelay_1;  // mémorise l'état du relay_1
int etatRelay_2;  // mémorise l'état du relay_2
unsigned long lastRelaiHighMillis = 0; // mémorise la dernière fois que le relai a été activé
unsigned long maxRelaiHighMillis =40*1000;// Temps maximum d'activation du relai (40 sec)
  irrecv.enableIRIn();
  pinMode (LED_1,OUTPUT);
  pinMode (LED_2,OUTPUT);
  etatRelay_1 = LOW;
  etatRelay_2 = LOW;
void action(decode_results *results) {
  int count = results->rawlen;
  if (results->decode_type == UNKNOWN) {
    switch (results->value) {
    case 0xE13DDA28:
      if (digitalRead(3) == HIGH)
        digitalWrite(LED_2,LOW);
        digitalWrite(LED_1,HIGH);
        etatRelay_1=HIGH;
        // Get current time
        lastRelaiHighMillis = currentMillis;
      else if (digitalRead(3) == LOW){
        etatRelay_1=HIGH;
        // Get current time
      Serial.println("Relay_1");
      delay(50);
    case 0xAD586662:
      if (digitalRead(2) == HIGH)
        digitalWrite(LED_1,LOW);
        digitalWrite(LED_2,HIGH);
        etatRelay_2=HIGH;
        // Get current time
      else if (digitalRead(2) == LOW){
        etatRelay_2=HIGH;
        // Get current time
        //Serial.println(currentMillis);
      Serial.println("Relay_2");
    case 0x273009C4:
      Serial.println("OK");
      etatRelay_1=LOW;
      etatRelay_2=LOW;
        // Get current time
  // Get current time
  unsigned long soustraction=(currentMillis-lastRelaiHighMillis);
// Faut-il désactivé le relai automatiquement ?
  // Si Relays LOW ne rien Faire
  /*if((etatRelay_1 == LOW)||(etatRelay_2 == LOW)){
    etatRelay_1 = LOW;
    etatRelay_2 = LOW;
  if( ((etatRelay_1 == HIGH)||(etatRelay_2 == HIGH)) && (soustraction >= maxRelaiHighMillis ) ) {
    //desactiver relay_1
    etatRelay_1 = LOW;
    etatRelay_2 = LOW;
    digitalWrite(LED_1, etatRelay_1 );
    digitalWrite(LED_2, etatRelay_2 );
  if (irrecv.decode(&results)) {
    action(&results);
    irrecv.resume(); // Receive the next value
    //Serial.println(etatRelay_1,etatRelay_2);
    //Serial.println(millis());
      Serial.println(soustraction);
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
Hi, not really sure what your problem is. Perhaps you could provide more detail.
In the meantime it might be worth checking this line:
  if (results->decode_type == UNKNOWN) {.....}
If the result is unknown then the value returned (results->value) will be meaningless.
If the signal is decoded and returns a supported protocol (like NEC) then you can use the ‘value’.
Is this somehow better than:
        lastRelaiHighMillis = millis();
Are you planning to deal with the case where digitalRead() returns something other than HIGH or LOW? What other values can it possibly return?
I don't understand what your problem is, either.
Edit:
40 is an int. 1000 is an int. Therefore, an int register will be used to store the result, which won't fit.
unsigned long maxRelaiHighMillis =40UL*1000UL;
Now, 40 and 1000 are unsigned longs, so an unsigned long register will be used to hold the result, which will fit.
32 seconds interval... may look like USB-port traffic..
Actually, the limit is probably 32.767 seconds...
