pb using BirdTerm (Java serial terminal) with Arduino
I want to use a light Windows application to communicate through USB with std arduino : after many researches, I found at least this one : http://sourceforge.net/projects/birdterm/ (and there is not a lot of software else this one !)
all is working like in the 1.05 IDE (written also in JAVA I think) but one thing is "boring" : as once a car is entered in the terminal, it is sent immediately so when you use for ex Serial.available () on arduino, like in this code :
char buffteleinfo[255] = "";   // chaine de caractère reçu par le compteur EDF (sert aussi a init reseau)
char buffer_lect[100]; // buffer de lecture auxilliaire taille mini 8 carac
byte inByte,l,k = 0;         // incoming serial byte
  // start serial port at 9600 bps:
  Serial.println("\nhello world!");     // entree params reseau
     inByte =0; l=0;
     Serial.println(F("entrer nom du reseau :"));
     while (!Serial.available()) {;}
while (Serial.available()>0) { // tant que saisie non depilée
      inByte=Serial.read();
      buffteleinfo[l] = inByte;
      l++;
 delay(10);  // important si 9600 bds
      buffteleinfo[l]=0;  // fin de la chaine
      Serial.println(buffteleinfo);
you can enter only one car... !! I have modified the code to detect an end caractere (='$') to finish the entry but it is ugly !! and of course, this car can't be a part of the entry !
somebody knows another simple freeware usable with this code, like in the Arduino IDE ? or another way of coding without using an end car. ?? here is my adapted code that works on BildTerm... (note that the entered car makes the cursor moving so I have added several Serial.println("") for that....)
     inByte =0; l=0;
     Serial.println(F("\nentrer nom du reseau et terminer par $"));
     do { // saisie car par car pour compatibilité Terminal Java ($ situé a coté de ENTREE)
      if (inByte!='
) Serial.write(inByte); // echo local pour Terminal       buffteleinfo[l++] = inByte;       delay(10);  // important si 9600 bds         }while (inByte != ' ```
);       buffteleinfo[--l]=0;  // decale fin de la chaine     Serial.println(F("")); ```
but it is ugly !!
Nonsense.
Carriage returns and/line feeds rarely are.
There are plenty of choices. First, you explain the problem with using the Serial Monitor application. Then, you mention what operating system you are using. Then we can help you.
I think the examples in serial input basics may do what you want.
...R
