pb wise servo programme
hello
i have a problème wis this programme
i cant gate the void aus to fonctionne and the int pos
#include<Servo.h>
Servo myservo1;
Servo myservo2;
int pos myservo1 = 60; // myservo1
int pos myservo2 = 55; //myservo2
  myservo1.attach(9);
  myservo2.attach(10);
void aus() {
    for (pos = 60; pos <= 0; pos +=1){
    myservo2.write(pos);
    delay(2);
    for (pos = 0; pos >= 60; pos -=1){
    delay(3)
  for (pos = 60; pos <= 70; pos +=1){
    myservo1.write(pos);
    delay(3);
    aus();
  for (pos = 70; pos <= 80; pos +=2){
    delay(3);
    aus();
  for (pos = 80; pos <= 90; pos +=3){
    delay(3);
    aus();
  for (pos = 90; pos <= 100; pos +=4){
    delay(3);
    aus();
  for (pos = 100; pos <= 110; pos +=5){
    delay(3);
    aus();
  for (pos = 110; pos <= 120; pos +=6){
    delay(3);
  for (pos = 120; pos >= 110; pos -=6){
    delay(3);
    aus();
  for (pos = 110; pos >= 100; pos -=5){
    delay(3);
    aus();
  for (pos = 100; pos >= 90; pos -=4){
    delay(3);
    aus();
  for (pos = 90; pos >= 80; pos -=3){
    delay(3);
    aus();
  for (pos = 80; pos >= 70; pos -=2){
    delay(3);
    aus();
  for (pos = 70; pos >= 60; pos -=1){
    delay(3);
    aus();
    delay(3);
thanks for your help
What’s that?
How many iterations of that loop do you expect?
for (pos = 0; pos >= 60; pos -=1)And again?
Syntax errors on those lines will cause errors in compiling. Since the code will not compile how do you know that the aus function won't work?
void aus() {
Another error that will prevent compiling. You cannot define a function within another function. And setup() is not a good name for any function but the one that actually does the processor setup (void setup()).
After you have made a few corrections as suggested it would be a good idea to post all the errors you get when you try to compile this program (in </> code tags please).
Steve
Have a look at the servo sweep example that comes with the Arduino IDE.
...R
