Sorry if this subject has already been brought up.
Looking into the Zero and M0 Pro schematics, pin 21 which is called PA12/I2C/EIC/SCOM2PAD0+/TC2 is connected to a wire named PB12_S4_SPI_MISO. The ATSAMD21G18A chip has no PB12, as far as I could tell, but does indeed have a PA12.
I have noticed several clones, from other companies, with the same "PB12" pin.
Is this some feature which I am failing to understand? Or is it that the SPI MISO has never been used by anyone (on planet Earth, I guess) before?
You're right, the SAMD21G microcontroller used on the Arduino Zero/M0 Pro doesn't have a PB12 pin. This pin is only available on its larger sibling, the 64-pin SAMD21J variant.
Thanks for the reply and confirmation. For me it is hard to understand/follow this issue. Under variants/arduino_zero" (I did not check other variants) the definitions in variant.h are:
