Hi guys,
How are you? I really hope you're all safe and healthy in particular during this emergency all entire world is facing up.
I'm writing this regarding a really weird problem with my Arduino M0 (Native USB port).
Until this morning, I've been working about timing my SAMD21 using overflow interrupt and I've reached a good result (in fact, I was very happy that my understanding about timing has been improved).
I was playing around with some trial, changing the clock frequency, Presclar, and stuff like that and at some point after I've uploaded my sketch through IDE something really strange happened.
My PC doesn't recognize Arduino either Serial port COM. So it is impossible to interface Arduino with IDE, but in general, my PC doesn't recognize it.
I tried to change the USB cable, nothing happened. I tried to change PC and appear the same message that you'll find attached (Sorry, it's in Italian but basically what it mentions is: The last USB device connected to the PC doesn't work and it wasn't recognized. Tips: Try to re-plug the device. If it is still doesn't recognize, it is possible that doesn't work properly).
The strange thing is that there's power supply over the board. I've checked with a multimeter and looks that all pin (of course, the ones that have to be) are powered. And moreover, the last sketch that I uploaded toggle a pin each tot second and using multimeter and even DAQ to collect data from the enquired Pin, looks that works perfectly. Then, basically what I mean is that last sketch uploaded works perfectly without problems.
Please, has someone any suggestions on how to sort out this problem? It's very important to me.
Your help is really appreciated, thanks in advance.
(mod edit)
