I moved your topic to a more appropriate forum category @huybui91.
The Nano ESP32 category you chose is only used for discussions directly related to the Arduino Nano ESP32 board.
In the future, please take the time to pick the forum category that best suits the subject of your question. There is an "About the _____ category" topic at the top of each category that explains its purpose.
Hi @huybui91. Check to make sure the USB cable is fully inserted into the socket on the board and computer. I have experienced that "Device can't start" error sometimes when the USB cable isn't getting a good connection. Maybe that is the cause of the error you are encountering as well.
If that doesn't help, try a different USB cable. It is possible the one you are using might be damaged, defective, or just too low of quality to work in this application.
