Hi all,
I'm using ATMEGA328P, Nano board and I want to wake up from deep sleep mode when I release a button (Not pressing it). My interrupts are normally closed and grounded if that helps. I've been stuck on this code for a long time now.
I just want to know why the interrupt can't wake it up from sleep.
Now in my code, I have a one-minute watchdog timer waking the board up (and it can read the interrupt after the one-minute delay) , But, I need to know immediately when the interrupt triggers.
Here's the code:
#include <arduino.h>
#include "HopeDuino_LoRa.h"
#include <avr/sleep.h>
#include "ArduinoUniqueID.h"
#include <stdlib.h>
#include <string.h>
#include <stdint.h>
#include <EEPROM.h>
#include <avr/wdt.h>
#include <avr/power.h>
#include "timer.h"
#include "timerManager.h"
#include <PinChangeInterrupt.h>
#define LEN 32
// Choose a valid PinChangeInterrupt pin of your Arduino board
#define buttonPin0 2
#define buttonPin1 3
#define buttonPin2 4
#define buttonPin3 9
#define buttonPin4 10
// variables will change:
volatile int stud0,stud1,stud2,stud3,stud4= 0; // variable for reading the pushbutton status
#define LED_PIN 15
#define LED_PORT() pinMode(LED_PIN,OUTPUT)
#define LED_HIGH() digitalWrite(LED_PIN,HIGH)
#define LED_LOW() digitalWrite(LED_PIN,LOW)
const char str0[]= "pair";
const char str1[]= "1";
const char str2[]= "2";
const char str3[]= "3";
const char str4[]= "4";
const char str5[]= "5";
const char str6[]= "b";
byte getstr[LEN];
byte mode = RX_MODE;
const byte app_syncword[] = { 0x2D, 0xD4, 0x56, 0x78, 0x9A, 0xBC, 0xDE, 0xF0 } ;
char output0[25];
char output1[25];
char output2[25];
char output3[25];
char output4[25];
char output5[25];
char output6[25];
void setup(void)
LED_PORT();
Modulation = LORA; ///Was FSK
COB = RFM95; // Was RFM95
Frequency = 915000; // was 866000
OutputPower = 3; //17dBm OutputPower
PreambleLength = 8; //8Byte preamble
FixedPktLength = true; //explicit header mode for LoRa
PayloadLength = 21;
CrcDisable = true ;
//for LORA parameter
SFSel = SF7;
BWSel = BW125K;
CRSel = CR4_5;
// initialize the pushbutton pin as an input:
pinMode(buttonPin0, INPUT);
pinMode(buttonPin1, INPUT);
pinMode(buttonPin2, INPUT);
pinMode(buttonPin3, INPUT);
pinMode(buttonPin4, INPUT);
// Attach the new PinChangeInterrupt and enable event function below
attachPCINT(digitalPinToPCINT(buttonPin0), pin_ISR1, RISING);
attachPCINT(digitalPinToPCINT(buttonPin1), pin_ISR2, RISING);
attachPCINT(digitalPinToPCINT(buttonPin2), pin_ISR3, RISING);
attachPCINT(digitalPinToPCINT(buttonPin3), pin_ISR4, RISING);
attachPCINT(digitalPinToPCINT(buttonPin4), pin_ISR5, RISING);
strcpy(output0,str0);
for(byte i = 0; i < 8; i++){
char idStr[4]; //need at least 1 (space) + 2 (id) + 1 (null termination)
sprintf(idStr, "%02x", UniqueID8[i]);
strcat(output0, idStr);}
strcpy(output1,str1);
for(byte i = 4; i < 8; i++){
strcat(output1, idStr);}
strcpy(output2,str2);
strcat(output2, idStr);}
strcpy(output3,str3);
strcat(output3, idStr);}
strcpy(output4,str4);
strcat(output4, idStr);}
strcpy(output5,str5);
strcat(output5, idStr);}
strcpy(output6,str6);
strcat(output6, idStr);}
vInitialize();
bSendMessage(output0,25);// Output0 is the pair message
_delay_ms(20);
_delay_ms(20);
myWatchdogEnable (0b000110); // 1 second
void loop(void)
vGoSleep();
static byte last_mode=RX_MODE;
pin_ISR1();
pin_ISR2();
pin_ISR3();
pin_ISR4();
pin_ISR5();
stud0 = digitalRead(buttonPin0);
stud1 = digitalRead(buttonPin1);
stud2 = digitalRead(buttonPin2);
stud3 = digitalRead(buttonPin3);
stud4 = digitalRead(buttonPin4);
if (stud0==1){ //It takes a long time to start the initial blink
vInitialize();
_delay_ms(10);
LED_HIGH();
bSendMessage(output1,25);
_delay_ms(125);
LED_LOW();
if (stud1==1){ //It takes a long time to start the initial blink
vInitialize();
_delay_ms(10);
LED_HIGH();
bSendMessage(output2,25);
_delay_ms(125);
LED_LOW();
if (stud2==1){ //It takes a long time to start the initial blink
vInitialize();
_delay_ms(10);
LED_HIGH();
bSendMessage(output3,25);
_delay_ms(125);
LED_LOW();
if (stud3==1){ //It takes a long time to start the initial blink
vInitialize();
_delay_ms(10);
LED_HIGH();
bSendMessage(output4,25);
_delay_ms(125);
LED_LOW();
if (stud4==1){ //It takes a long time to start the initial blink
vInitialize();
_delay_ms(10);
LED_HIGH();
bSendMessage(output5,25);
_delay_ms(125);
LED_LOW();
* Watchdog timer
// sleep bit patterns:
// 1 second: 0b000110
// 2 seconds: 0b000111
// 4 seconds: 0b100000
// 8 seconds: 0b100001
myWatchdogEnable (0b100001); // 8 seconds
myWatchdogEnable (0b000111); // 2 seconds
void pin_ISR1() {
digitalWrite(LED_PIN, stud0);
void pin_ISR2() {
stud0 = digitalRead(buttonPin1);
digitalWrite(LED_PIN, stud1);
void pin_ISR3() {
stud0 = digitalRead(buttonPin2);
digitalWrite(LED_PIN, stud2);
void pin_ISR4() {
stud0 = digitalRead(buttonPin3);
digitalWrite(LED_PIN, stud3);
void pin_ISR5() {
stud0 = digitalRead(buttonPin4);
digitalWrite(LED_PIN, stud4);
ISR(WDT_vect)
wdt_disable(); // disable watchdog
void myWatchdogEnable(const byte interval)
vGoSleep();
MCUSR = 0; // reset various flags
WDTCSR |= 0b00011000; // see docs, set WDCE, WDE
WDTCSR = 0b01000000 | interval; // set WDIE, and appropriate delay
wdt_reset();
// disable ADC
ADCSRA = 0;
set_sleep_mode (SLEEP_MODE_PWR_DOWN);
cli(); // timed sequence follows
sleep_enable();
// turn off brown-out enable in software
MCUCR = bit (BODS) | bit (BODSE);
MCUCR = bit (BODS);
sei(); // guarantees next instruction executed
//sleep_cpu (); // now goes to Sleep and waits for the interrupt
sleep_mode(); //goes to sleep faster than Sleep_CPU
