The red light could indicate that you have a clone (my Mega has a green On). The flashing green on your board is more than likely the L led and flashes due to the pre-loaded blink skitch.
Possibly.
Clones oftem use the CH340 TTL-to-USB converter; it's the chip closest to the USB port. If it's a square chip with legs at all side, it's more than likely a 16U2 and the board should work; if it's rectangular with legs at two sides, it's probably a CH340. The prints are often difficult to read but under the right angle (maybe take a macro photo and check that) it should be possible.
Please explain. Did you install them by running the exe? Once done, it should say something like "sucessfully pre-installed". The board indeed uses the CH340.
Assuming that you're running Windows (else you would not have to go through the exercise), what does device manager think of your board?
Bad cable or cable not fully inserted at one or both ends can be a cause. Do you have any other devices (e.g. printer) that use the same type of cable to check if the cable is OK?
Broken CH340 and bad soldering on the board can be another cause.
Sorry I'm so new here, what's a pre-loaded blink skitch?
I'm stuck back on the fact my PC doesn't make any sounds like it does when i connect any other USB including my Leonardo. I can't see it in my Devices.
When I try uninstall CH341SER I get 'No device found' when I installed the driver I get 'The drive is successfully Pre-installed in advance' uninstall it after, same message.
Blink is a sketch and flashes the L led one second on, one second off. If that is what you see, your main processor (2560) is OK.
Try different cables; although I 'm not aware of cables with the big B connector that are charge only and don't carry data, it might be a possibility. Do you have an Uno to test the cable?
When I unplug the device and go into the Arduino IDE, under ports I see COM3 and COM4. When I plug it in, I see the same thing.
On a laptop I see no ports when not plugged in and COM5 when plugged in.
When I try use the example > Basic > Blink I click COM4 and upload I get errors. Do the same thing and change to COM3 and It says uploaded and does nothing. just sits on uploading.
So, are you saying that you were using a USB hub previously and now have it connected to the PC motherboard USB ports?
Thanks for updating the forum. Might help someone else down the road.
This type of behaviour can be seen with other devices too. I have now made it a habit to plug a USB device directly into the PC without using a hub if it is the first time I'm using it, Helps keep hair attached to head
