Good afternoon, I'm planning on powering my arduino from the 12v rail of a PC power supply. I'll be powering other stuff (just a servo, intially) from the 5v rail.
To have a common ground will I need to use the same ground pin, on the same power chain from the PSU?
I know from experience that the different power lines [by lines I mean the physical branches of power leads coming out of the PSU] coming out of a PSU are somehow separated (if I suddenly add load on one, something else on that line might stop working. Doesn't happen to devices on other lines) but I've no idea whether that's just because of serial/parallel difference or because there's something more complicated going on. And, more importantly, whether that means the grounds are on different lines aren't common.
Thanks. I hope this makes sense, I seem to have rambled a bit.
