pc starter
Hello
i have a few question regarding a project i am trying. i am fairly new to the whole microcontroller an electronics thing but i want to try it.
i want to start a pc trough arduino and test if its on or not.
so i thought power button for starting/shutdown and case led for testing.
and i came up with the attached schematic.
the idea is. short the power switch pins on the motherboard with a transistor.
an let the led control a transistor to measure if the pc is on.
but i'm not really sure if this would work as expected. Especially the led/transistor part.
thanks in advance for any input on this
Have you ever lgoogled for "wake on lan"? if your network card supports taht it might be the easiest way todo.
I would propose to use a small relay iso a transistor (decoupling)
thanks
yes i know about wake on lan. the motherboard supports it, and i tried to get it to work but even with correct bios settings an linux tool the pc wont boot
on the other hand, a project like this betters my understanding about electronics, so i'm choosing this route to learn something along the way.
did you mean using a relay instead of the transistor connected to the led or for both ?
Changed the whole thing to use only optocouplers and include the reset switch too.
is this layout correct ? (without the part numbers, chose those at random)
should this work as expected ?
do i need resistors on some places ?
thanks in advance
