Hello Community! I have just finished a simple piece of equipment to control the case fan inside my PC tower. My setup allows it to be mounted inside the case, and it only needs a serial connection when you set its threshold, so you can see what the actual amount is. You use a pot to adjust the threshold from 30 to 80 degrees Celsius, the average range in my PC with a little room to spare. It has two indicator LEDs and it uses a 5v relay. You can always modify it!
My code is and will always be in the public domain, so enjoy it as you wish! I only ask what you did with it so I can get some ideas. Thanks!
//You need: a TMP36 sensor, 2 LEDs of choice, resistors for those LEDs, a 10k Pot, a 5v relay, and a PC fan to control
const int relayPin = 12; //a pin to control the relay
const int controlPin = A1; //receive the thermostat setting
const int thermoSensor = A0; //the temp sensor
const int ledOn = 5; //some status LEDs, this one is Green
const int ledOff = 4; //this one is Red
double threshhold; //store the pot value as a desired 'set' temp.
double voltageReading; //variables to calculate and store the temperature in Celsius
double pcTemperature; //the ambient temperature inside the case
pinMode(thermoSensor, INPUT); //the sensors
pinMode(controlPin, INPUT);
pinMode(relayPin, OUTPUT); //the output devices
pinMode(ledOn, OUTPUT);
pinMode(ledOff, OUTPUT);
threshhold = analogRead(controlPin); //doing it like this for simplicity
threshhold = map(threshhold, 0, 1023, 10, 30); //30 Celsius to 80 Celsius, but for debugging, 10 to 30 degrees
pcTemperature = pcReading(); //get the temp
if (pcTemperature >= threshhold)
fanOn();
if (pcTemperature < threshhold)
fanOff();
displayStats(threshhold, pcTemperature); //show some information to help set the device
int pcReading() //get the temperature information from the PC
int reading = analogRead(thermoSensor); //read the voltage
float voltage = reading * 5.0; //multiply it by the power supplied to the sensor (5v)
voltage /= 1024.0; //turn it into an easier value to calculate
float temperatureC = (voltage - 0.5) * 100 ; //calculate temperature in Celsius
return temperatureC;
void fanOn()
digitalWrite(ledOn, HIGH); //update the signals
digitalWrite(ledOff, LOW);
digitalWrite(relayPin, HIGH); //activate the relay
void fanOff()
digitalWrite(ledOn, LOW); //update the signals
digitalWrite(ledOff, HIGH);
digitalWrite(relayPin, HIGH); //deactivate the relay
void displayStats(double threshhold, double pcTemperature)
Serial.print("SET ");
Serial.println(threshhold);
Serial.print("CURRENT ");
Serial.println(pcTemperature);
Serial.end();
