had time to kill so here's some code based on the datasheet example and the git link your shared since you could not be bothered to attempt it youself!
(Compiles, NOT tested!)
#include <Wire.h>
#define PCA9553_01_I2C_Addr 0x62
#define PCA9553_02_I2C_Addr 0x63
/* ls_val
00 = output is set LOW (LED on)
01 = output is set high-impedance (LED off; default)
10 = output blinks at PWM0 rate
11 = output blinks at PWM1 rate
char *led_status[4] = {"ON", "OFF(INPUT)", "PWM0", "PWM1"};
enum ls0_mode {ON, OFF_INPUT, PWM0, PWM1};
enum LEDx {LED0, LED1, LED2, LED3};
struct PCA_regs
uint8_t IO;
uint8_t PSC0;
uint8_t PWM0;
uint8_t PSC1;
uint8_t PWM1;
uint8_t LS0;
} pca_regs;
uint8_t IO_Read(int Addr, enum LEDx led_num) {
uint8_t ip;
Wire.beginTransmission(Addr);
Wire.write(0x00); //don't set auto-increment for reading input port
Wire.endTransmission(); //end transmission
Wire.requestFrom(Addr, 1); // request 1 byte
ip = Wire.read(); // receive a byte
return ((ip >> ((uint8_t)led_num + 4)) & 0x01);
uint8_t Get_LED_Mode(uint8_t ls0, enum LEDx led_num) {
return ((ls0 >> ((uint8_t)led_num * 2)) & 0x03);
void Set_LED_Mode(uint8_t *ls0, enum LEDx led_num, enum ls0_mode m) {
uint8_t temp = (((uint8_t)m) << ((uint8_t)led_num * 2));
uint8_t mask = ~(0x03 << ((uint8_t)led_num * 2));
*ls0 = (*ls0 & mask) | temp;
void PCA9553_read_registers(int Addr, struct PCA_regs *regs) {
uint8_t buf[6];
Wire.beginTransmission(Addr); // initialise transmit to device
Wire.write(0x10); //set auto-increment for reading all registers
Wire.requestFrom(Addr, 6); // request 6 bytes from device
for (uint8_t i = 0; i < 6; ++i) {
buf[i] = Wire.read(); // receive a byte
memcpy(regs, buf, 6);
regs->IO = Wire.read(); // receive a byte
void print_regs() {
Serial.print("INPUT(read-only): ");
Serial.println(pca_regs.IO, BIN);
Serial.print("PSC0: ");
Serial.println(pca_regs.PSC0, BIN);
Serial.print("PWM0: ");
Serial.println(pca_regs.PWM0, BIN);
Serial.print("PSC1: ");
Serial.print("PWM1: ");
Serial.print("LS0: ");
Serial.println(pca_regs.LS0, BIN);
Serial.print("LED0 Mode: ");
Serial.println(led_status[Get_LED_Mode(pca_regs.LS0, LED0)]);
Serial.print("LED1 Mode: ");
Serial.println(led_status[Get_LED_Mode(pca_regs.LS0, LED1)]);
Serial.print("LED2 Mode: ");
Serial.println(led_status[Get_LED_Mode(pca_regs.LS0, LED2)]);
Serial.print("LED3 Mode: ");
Serial.println(led_status[Get_LED_Mode(pca_regs.LS0, LED3)]);
Wire.begin(); // join i2c bus (address optional for master)
Serial.println("----PCA9553 Example Code----");
Serial.println("Current Register Status:");
PCA9553_read_registers(PCA9553_01_I2C_Addr, &pca_regs); //assuming chip part number is PCA9553/01
print_regs();
Wire.beginTransmission(PCA9553_01_I2C_Addr); //assuming chip part number is PCA9553/01
Wire.write(0x11); //PSC0 subaddress + Auto-Increment
Wire.write(0x2B); //Set prescaler PSC0 to achieve a period of 1 second:
Wire.write(0x80); //Set PWM0 duty cycle to 50 %
Wire.write(0x0A); //Set prescaler PSC1 to achieve a period of 0.25 seconds:
Wire.write(0xC0); //Set PWM1 output duty cycle to 25 %:
//Set LED0 on, LED1 off, LED2 set to blink at PSC0, PWM0, LED3 set to blink at PSC1, PWM1
uint8_t ls0;
Set_LED_Mode(&ls0, LED0, ON);
Set_LED_Mode(&ls0, LED1, OFF_INPUT);
Set_LED_Mode(&ls0, LED2, PWM0);
Set_LED_Mode(&ls0, LED3, PWM1);
Wire.write(ls0);
Serial.println("Register Status After Update:");
print_regs();
//nothing here
if you're not sure of your chip's address, you can always try using this I2cScanner code to find out!
