Pca9685 current requirement
Hi im doing a project with arduino and pca9685 where i need to control 6 servos
How much current do i need to control them or which battery can i use.
Thank you
Welcome to the forum
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
Look at the specs for the servos. Let's say each setvo requires 500 mA, that would result in 3 A. Add a little for the additional electronics if they are power from the same source.
The battery depends on how long you need it to run. If you have a 3000 mAh battery, it can deliver 3 A for one hour.
I don't now anything about servos; if they only draw significant current while moving, your battery can last longer, if they continuously draw it will be the hour.
