PCA9685 issue
I´m having a problem w/ servos moving uncontrollably - I have 3 SG90 that work fine on their own, but when I attach a larger BMS620MG and give it a separate command they all move around quite at will.
They all run from a 6V independent source. I also tried to switch off them using setPWM, to no avail.
I use the Adafruit 9685 library.
Just to clarify for others reading this: the "A9685" above refers to the PCA9685.
show us your code
if you are having trouble setting it up go to https://www.brainy-bits.com/control-multiple-servos-with-joystick/
their website and watch the two vids and there is a link to the library at the bottom of the page.
