PCA9685 powering 160 RGB leds
Hi:
Newbie here, I'm using the PCA9685 and Adafruit library. Which has 16 Channel, 12bit pwm
However I am facing issue to power 160 RGB leds split into 5 groups each has 3 channel.
40 leds per channel.
one RGB led is taking 20ma
I need about 3.2A to power all of them.
My question is :- 1. Is it possible I drive all the RGB Leds with a common anode of constant power from 5A ubec then sink them with the pwm pin ?
  1. or I need to use common cathod RGB leds with one mosfet (IRLU024N) each per channel ?
Regards, Raymond
1) No
2) No
Anyone could enlight me on what is the needed component to make this work ?
Regards, Raymond
Wrong chip.
To make it work (for common anode LEDs), you need
15 logic level mosfets
160 * 3 = 480 resistors
and a 5volt 160 * 3 * 0.02A = 9.6Amp supply.
Addressable LEDs (or LED strip) would have been easier. Leo..
Really Thanks alot for your help Leo !
