Pcb board
Making boards.
I came across a thread then lost it.
Looking to have 200 to possibly 500 made.
Smt arduino plus some extra smt of about same amount of components.
Some connectors. Probably 6 pin only through hole ,with isp and others done with edge connector fingers but with some board routing.
Board would be epoxy of a thickness that would allow insertion into a standard usb cable.
1.6 mm board seems to be not quite right somehow.
Any advice appreciated.
I have had some wildely different quotes with test files.
Any guidance appreciated.
I use www.elecrow.com for my PCB's
They can also source your components from a BOM and build a finished item, or you can send the components for build.
Any minimum requirements?
You can get thinner, right down to 20mil AFAIK.
Try pcbcart.com, I find them pretty good but I've not used their PCBA service yet. They have an on-line pricing system which is good, easier than getting quotes all the time.
Rob
I've not yet used the PCBA servicenat Elecrow but I am very happy with their fabrication service, comms and quality.
PCBA @ http://www.elecrow.com/mobile/ui/product.php?id=366&s=2773676269838
There doesn't seem to be any minimum quantity but there are surcharges for under 20 units.
They have a good quide so you can estimate a price yourself before obtaining a formal quote.
