Hello, I'm intended to create a custom PCB with a SIM7080G module on it.
I have several questions in mind, the first one is about the power supply capacitors.
The module's Hardware Design guide recommends this circuit:
I'm not a hardware expert but I'd say that the first two capacitors (100nF and 1µF) are non-polarized capacitors (indicated by the parallel lines), which is typical for ceramic or film capacitors. These types of capacitors are used for high-frequency decoupling and to filter out fast transients ➜ the goal is stabilizing the power supply and reducing noise.
The last three 100nF capacitors, are polarized capacitors (as indicated by the straight line with a plus sign and a curved line connected to ground). These are likely electrolytic or tantalum capacitors, which are used for bulk capacitance (bulk energy storage) and to filter low-frequency ripple or smooth the output voltage in the power supply.
To your question on why 3 rather than a larger one, I think (expert will confirm) that multiple smaller capacitors have a lower total Equivalent Series Resistance than a single larger capacitor, which improves the filtering of high-frequency noise.
They should probably work but typically have a higher ESR compared to Tantalum capacitors.
Supporting @J-M-L's reply.
What voltages on Vbat are allowed? What other devices would be using the same Vbat?
Maybe You can use a temporary protoboard for testing other variants of the large caps before making the PCB?
There seems to conflicting information in the design document about power supply design.
The buck design only shows 2 capacitors, the reference design shows only one polarized cap.
Is there a reference design document?
How will you be powering the IC?
@J-M-L Yes, those are bypass capacitors. The question is rather about the polarized caps.
These Aluminum Electrolytic types can have really low ESR, I have found one a 100uF/16V with 360mOhm.
Only small consumers will be on the board. (max. 20mA)
There is an already working board which I bought separately: 7080X HAT Schematic.
This seems to be working good, powered only from VBAT pin (the MP1482 regulator on it does not get any voltage). I'm basically trying to "mimic" this board, but also keeping the design document in mind.
The first difference was this VBAT input capacitor usage, this is why I started the topic.
I'm not aware of anything like that.
Basically it will be powered from a large single li-ion battery cell.
The device which is now under testing and seems to be working OK, is a simple ATmega328P board also powered from a single battery cell and connected to this SIM7080G board. The power for the 7080G board goes through the VBAT pin, as I already mentioned.
Now that I've written this much about it, if this board can work with the altered capacitor layout, maybe I shouldn't insist on the 3x100uF design? The tested board has these capacitors on VBAT (picture from the linked schematic):
Did you read post #4?
Did you read look at the other parts of the document that mention power supply design that I pointed out?
The PI HAT design seems a little wierd.
Why 33pf and 10pf?
Must be a layout issue.
Yes, I've read it, but I think that the different capacitor usage in case of Buck converter is understandable.
But I have no idea why the reference design on p.68 and the HAT design on VBAT pin is so different.
Also, when I look at the board, it actually doesn’t have a polarized capacitor at all.
This is getting weirder and weirder..
As explained in the datasheet the reason for the capacitors is to keep the voltage from drooping when the device starts to pull more current. So what would cause the voltage to droop? Resistance and inductance of whatever is between the Vbat pins and the power source would cause such a droop. If there was none then you would not need the capacitors at all.
In the one example they have a ferrite in the line supposedly for noise filtering but it also impedes the flow of current to the device so they have more capacitors there
In the other example the have one polarized 100uF and two non polarized 100uF and a 1uF. That seems reasonable and probably cover most designs.
In the Pi HAT the power source is very close to the PCB so the need for a lot of bulk capacitance is not needed as there would not be a lot of resistance and inductance. However the need for the pF capacitors is unknown but there could be noise problems since this board sits on top of a high powered microprocessor.
If I was doing this I think I would use a 0.1uF ceramic, two 100uF ceramics all placed close to the Vbat pins and a 100uF aluminum-polymer capacitor close to where the power enters the PCB
I suppose it's for noise filtering purposes. Since I will only use 9600 baud for UART communication, the larger (and possibly better at filtering) capacitor would be a better choice, right?
You are right, my bad. I edited the post with the whole circuit. So the larger capacitor is used because of the added 100k resistor?
Why add the 100k resistor? My only guess is that it prevents any accidental short circuit with different voltage levels (VCC_UP can be selected with a jumper on this HAT).
It might be true, but it's a relatively weak pull-up resistor, especially considering the additional 100nF capacitor. Ok, I will omit the 100k pull-up. But what about the capacitor should it be 33pF or 100nF?
The next thing is the RF antenna circuit, the design document shows NC capacitors and 0R.
These are prepared for the case if a "non-50Ohm" impedance antenna is used, right?
I'm still stuck with the RF antenna routing. The Hw design document has an RF trace note section on p.49 which is mostly understandable, but there is one note I can't interpret at all:
"GND pads around the ANT pad should not be hot pad to keep the GND complete"
What does "hot pad" mean? Does this mean I shouldn't connect these pads to GND at all?
The note refers to PIN 30/31/33 I think, the RF pin is 32.
What you have to remember that what you posted in your opening post is a schematic, it is not a wiring diagram. So this is a way of showing the number of capacitors in total there are in the circuit.
It is not showing you where they are put. It needs a bit more skill to know where to put them to be effective. They have to be close to the parts of the circuit that needs them.
No it must still be connected to ground.
Pads can have thermal relief around them, to prevent all the heat being drawn out of the soldering iron, or solder wave, when they are soldered.
Yes, my main problem was that the schematics I looked at showed different capacitor numbers/values. (as @LarryD also pointed out)
Okay, I see. So, vias should be placed all around these pads. Maybe I should add a dedicated GND copper zone also on the top side, in addition to the to the existing ground plane on the bottom side.
