PCB Enclosure
Do you guys know where I can find enclosures like this one?
Spend some time on ebay.
https://www.ebay.ca/sch/Computer-Cases-Accessories/175674/m.html?_ipg=50&_sop=12&_ssn=worldchips
Start with a box and cut holes where you want. The big suppliers like Mouser have thousands of different types and sizes.
Or www.polycase.com
I've looked a lot of places already. I've tried google, amazon, alibaba, aliexpress, polycase, mouser, allied, jameco, newark,etc. I cannot seem to find the same case and is hoping someone would know where to find such a case.
Looks like injection molded ABS plastic. Get a 3D printer and make your own.
Paul
Where did you find the first one, or the photo of it? That'd be a starting place to get more of them.
That type of case with mounting "ears" to bolt it down to a surface is called a "bulkhead case". Use that term in your search.
I think the term originates on boats, where a vertical wall between cabins is called a "bulkhead". Electrical equipment attached to the bulkhead must have a bulkhead case so you can get the screws in easily.
3d printer would be nice but I just need a similar case. i dont want to invest in a 3d printer. Plus the quality is not production ready. Wall mount type with rounded tabs. Screw should be from the bottom and not the top. The picture I found was from another product. I was hoping someone knew who manufactured it so I can get something like it. I found other alternative but the design of the box is not as nice.
that case is most likely made for one company, to their design.
most case manufacturers will make the dies for you at a price, then charge for each run of a thousand or so.
you can buy a case of that shape, then cut your own openings.
you can search ali express and send bid requests with that photo, with good luck, that supplier will find you.
my hunch is that these people will be able to custom make these for you.
you have to get past the on-line seller (call center) and get to custom manufacturing. the call center only offers from the on-line options.
szomk
For custom jobs don't go to aliexpress, go to alibaba instead. That's where I found the company to make my prototypes (usually done by CNC, and only natural colour plastic available, so if you need it black you have to paint it).
Expect to pay USD 20-100 for a single set, depending on size and complexity.
I plugged the image into Google images and most of the hits came from aquatic stores. The box is used for a lot of different stuff. Should be able to track down the supplier with a few phone calls. It is a nice box, but then so is an Altoids box mounted to a electrical gang box cover.
wvmarle:
ummm. AliExpress IS alibaba.
Alibaba GroupAlibaba Group Website, AliExpress, Alimama, Alipay, Fliggy, Alibaba Cloud, Alibaba International, AliTelecom, DingTalk, Juhuasuan, Taobao Markertplace, Tmall, Xiami, YunOS, 1688
Same company, different website with different purpose.
