hi guys
I use MP2305DS to convert 12V 5A to 3.3V 2A
I use pcb in the standard box ip68
Does the temperature affect the working pcb circuit?
Temperature will matter.
Voltage will be dependent on temperature (but this will be probably less than 100 mV per ten degrees C).
Also, your system will produce heat. If this heat cannot go anywhere, your power supply will get overheated and might shut itself down or get damaged.
In general, it is best if you can hold your hand on the components without burning yourself...
