PCB Relay reccomendation
Hi all,
Can anyone recommend a small sized, PCB mounted SPST relay with
12v coil (not more than 0.4W)
230V AC/10A (or more) contact
The above is needed for a building automation project and it is expected to remain energized for long periods of time.
I have used this one so far, but I am looking at the possibility of change since I am now re-designing the PCB.
Thanks!
Do some browsing
If it will be energized for long periods of time, perhaps a Latching Relay could be used - current pulse one direction to close the contacts, current pulse the other direction to open the contacts. Some have one set of coils for that, some have 2.
A while back I played with this relay. It's great for a battery powered solution, like my arduino based LC meter since it is only ever briefly energized.
Affordable Latching Relay
