PCF8563 RTC I2C not working with Arduino
I have an RTC circuit with an Arduino UNO using a PCF8563 breakout (https://www.amazon.ca/PCF8563-PCF8563T-Clock-Module Arduino/dp/B01DB8JECC). I've tried several libraries and all of them have the same problem that connecting does not work. Using the I2C scanner does not show it:
Scanning...
No I2C devices found
My circuit is:
Arduino Breakout
5V VCC
GND GND
SDA SDA
SCL SCL
I have also tried using the A4/A5 pins and that did not work either. I have tried with a 10k pull-up resistor (from SDA -> VCC and SCL -> VCC) and without.
If this schematic matches your module, then there are already quite strong (1k) pullup resistors on SDA and SCL https://www.waveshare.com/w/upload/b/be/PCF8563-Schematic.pdf (just something to consider if you add more I2C devices to the same bus).
What Arduino board are you using ?
An Arduino UNO R3:
Do you have the battery installed? Some boards do not function without the battery, even if connected to VCC.
I do have the battery installed.
Then your wiring or breadboard or module must be faulty. What does your setup look like?
I also tried putting the SDA/SCL directly to the SDA/SCL pins
I cant really be sure from the photo, but is the RTC actually soldered to the header pins, or just sitting on them?
It is not yet soldered to the header pins, could that be the problem?
Yes!
Don't feel too bad, as you're not the first poster to have done this, so I knew to look closely at the joints. :wink:
Thank you, that worked!
