Hi all,
I need some help:
I got a 2,5 digit lcd display (16 pins 1 backpane) controlled with a PCF8566 display driver. I got it working (got output to the display) My sketch is from this forum, but uses 1:4 drive.
I want to use static drive. With static drive I assume I can write to each separate segment. This allows me to use a for loop to write to the segments.
Question:
- Is my assumption right?
- How to select static drive?
http://www.nxp.com/documents/data_sheet/PCF8566.pdf
My setup: S0 to S13 connected to segment 1 tot 14.
My code:
#include <Wire.h>
#define DRIVER_ADDR 0x3E // 7 bit add
#define PCF_CONTINUE (1 << 7)
#define PCF_CMD_SET_MODE ((1 << 6))
#define PCF_MODE_LOW_POWER (1 << 4)
#define PCF_MODE_ENABLE (1 << 3)
#define PCF_MODE_HALF_BIAS (1 << 2)
#define PCF_MODE_THIRD_BIAS 0
#define PCF_MODE_MULTIPLEX_4 0 // Multiplex 1:4
#define PCF_MODE_STATIC 1
//Deze werkt!!!!
//#include <Wire.h> // I2C Master lib for ATTinys which use USI
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
//pinMode(0, OUTPUT); //LED on Model B
pinMode(1, OUTPUT); //LED on Model A
pinMode(2, INPUT_PULLUP); //TWI
pinMode(0, INPUT_PULLUP); //TWI
Wire.begin(); // initialize I2C lib
// the loop routine runs over and over again forever:
char start=0;
if ( start ==0 ) // do one not in the init wait power stable
start =1;
Wire.beginTransmission(DRIVER_ADDR);
Wire.write(0x60 |PCF_CONTINUE); // subadd device
Wire.write(0x48 |PCF_CONTINUE ); // 0x48 , enable driver 1:4
Wire.write(0); // clear pointer
Wire.endTransmission(); // Send 1 byte to the slave
// digitalWrite(1, HIGH); // drive led high
// delay(1000); // wait for a second
Wire.write(0x00); // clear pointer
// for (int i = 0; i < 12; i++) { // send 12 byte 24 x 4
Wire.write(0xaa);// S0 0xaa weergeven op display
delay(10);
//Wire.write(0xaa);// S1 0xaa weergeven op display
delay(10);
//Wire.write(0xaa);// S2 0xaa weergeven op display
delay(10);
//Wire.write(0xaa);// S3 0xaa weergeven op display
delay(10);
//Wire.write(0xaa);// S4 0xaa weergeven op display
delay(10);
//Wire.write(0xaa);// S5 0xaa weergeven op display
delay(10);
//Wire.write(0xaa);// S6 0xaa weergeven op display
delay(10);
// 0x55 // clears display
Wire.write(0xaa);// S7 0xaa weergeven op display
delay(10);
Wire.write(0xaa);// S8 0xaa weergeven op display
delay(10);
Wire.write(0xaa);// S9 0xaa weergeven op display
delay(10);
Wire.write(0xaa);// S10 0xaa weergeven op display
delay(10);
Wire.write(0xaa);// S11 0xaa weergeven op display
delay(10);
Wire.write(0xaa);// S12 0xaa weergeven op display
delay(10);
Wire.write(0xaa);// S13 0xaa weergeven op display
delay(10);
// digitalWrite(1, LOW); // drive LED low
delay(500); // wait for a second
Wire.write(0x00);
Wire.write(0x55); // 0x55 // empty display
delay(10);
