PCF8574 sur I2C
Merci pour ces informations.
Bonjour
A toutes fins utiles, si vous avez un doute sur l'adresse du composant, vous pouvez utiliser un "sniffer" qui joint successivement plusieurs adresses et renvoie celle(s) qui répond(ent).
Un exemple :
#include <Wire.h>
  delay(5000);
  Wire.begin();
  Serial.println("\nI2C Scanner");
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 1; address < 254; address++ ){
     Serial.print("Scaning address 0x");
     Serial.print("0");
     Serial.println(address,HEX);
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0){
      Serial.print("I2C device found at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.print(address,HEX);
      Serial.println("  !");
      nDevices++;
    }else if (error==4){
      Serial.print("Unknow error at address 0x");
      if (address<16)
        Serial.print("0");
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
    Serial.println("done\n");
Serial.println("--------------------------");
  delay(10000);           // wait 5 seconds for next scan
