PCF8574 value = PCF_38.read8(); only returns 255 - resolved - device dead
I have three waveshare PCF8574, one works perfectly read and write.
The other two only return 255 for value = PCF_38.read8();
The PCF8574 is connected to UNO I2C with 4K7 resistor on sla and sda line to 3.3v . Found a link that said I should use 3.3 not 5v oops, and have changed the voltage, didn't fix the problem though.
The test program is from the forum // FILE: pcf8574_test.ino // AUTHOR: Rob Tillaart with some Serial.print added.
partial results of test of good device
test 0
value of #38: 0
value of #38: 1
value of #38: 2
value of #38: 3
value of #38: 4
value of #38: 254
value of #38: 255
partial results of test of less than good device
test 0
value of #38: 255
value of #38: 255
value of #38: 255
value of #38: 255
value of #38: 255
value of #38: 255
value of #38: 255
//    DATE: 27-08-2013
// PUPROSE: demo
#include "PCF8574.h"
#include <Wire.h>
// adjust addresses if needed
PCF8574 PCF_38(0x38);  // add switches to lines  (used as input)
PCF8574 PCF_39(0x39);  // add leds to lines      (used as output)
	delay(20);
	Serial.print(" ");
	Serial.print(" ");
	Serial.print("------------------------------------------------------");
	Serial.print("-- setup ---");
	Serial.println("\nTEST PCF8574\n");
	uint8_t value =0;
	Serial.println("test 0 ");
	for (int i = 0; i< 256; i++)
		PCF_39.write8(i);
		Serial.print("value of #38:\t");
		Serial.println(value);
		delay(10);
	Serial.println("test 1");
	PCF_39.write(0, 1);
	for (int i = 0; i<7; i++)
		PCF_39.shiftLeft();
		delay(10);
	Serial.println("test 2");
		PCF_39.shiftRight();
		delay(10);
	Serial.println("test 3");
	for (int i = 0; i<8; i++)
		PCF_39.write(i, 1);
		Serial.print(i);
		Serial.println(",1");
		delay(10);
		PCF_39.write(i, 0);
		delay(10);
	Serial.print("4");
		PCF_39.toggle(i);
		Serial.print("toggle i");
		Serial.println(i);
		delay(10);
		PCF_39.toggle(i);
		delay(10);
	Serial.print("-- end of setup ---");
// END OF FILE
Not sure what the question is. It sounds like you have one good device and two faulty ones. Have you tried them one at a time? If so they are broken.
I was actually hoping that someone would say, have you run the fixme command.
But I can live with broken.
thanks
