PCF8574AN configured as output for relay
No,
you haven't got what I put.
  int Stereovalue = analogRead(A2);                 // Read the Stereo input on Analog pin 2:
  float Stereo = Stereovalue * (4.5 / 1023.0);      // Convert the Stereo value to a voltage
  if (Stereo<1)                                     // A Stereo signal wil be present Lower then 1 volts!(0,8v) Mono = 3,6v
 void setOutptr(byte bitToChange)
    Wire.beginTransmission(PCF2_output);
    outputData |= 1 << bitToChange;
    Wire.write(outputData);                         // set the bit and leave the others alone
    Wire.endTransmission();
    digitalWrite(Stereoled, HIGH);                  // Turn Stereo LED "ON" when Tuner receive a Stereo signal
    lcd.setCursor(21,0);
    lcd.print("S");                                 // display Stereo signal received
 void clearOutptr(byte bitToChange)
    outputData &= ~(1<<bitToChange);
    Wire.write(outputData);                         //  clear the bit and leave the others alone
    digitalWrite(Stereoled, LOW);                   // Turn Stereo LED "OFF" when there is no Stereo signal
    lcd.print("M");                                 // display Mono signal received
The statement should be
This sets the appropriate bit to a 1 without altering any of the other bits. The << is a shift to the left, you shift a one by as many bits to the left as the number of the bit you want to change.
Similarly when you want to clear a bit you create a number with a one in the bit you want to change, then you invert it, that is swap all the zeros and ones. Then you AND it with the number, this clears the bit.
outputData &= ~(1<< bitToChange);
sorry, i dont get it working.
when you want to turn it off then use
setOutput(4);
clearOutput(4);
also where to put those
What I gave you was two functions to turn on and off individual bits in your interface.
clearOutput(4);
You put them in your code when ever you want to turn something on or off. Specifically when you want to turn bit 4 off. If you want to turn bit 1 off you would put clearOutput(1) ; if you want to turn bit 6 off you would use clearOutput(6) ; if you want to turn bit 8 off then you understand even less because there is no bit 8 in your interface.
The code you just posted is a nonsense, it contains a function definition in the middle of a function, that does not make sense and the compiler no doubt tells you so. The functions I gave you must be put separately at the end of your code. Then in the code you call the functions when ever you want to turn something on or off. That will be turned on or off without affecting any other things attached to the same expander. Which is what I thought you wanted.
I don't think you know enough about programming to do your project. I would advise you learning some very basic fundamentals of programming. Like what is a function.
thanks for posting Mike,
just with some help i almost finish the project.
it is only this past part with the PCF what makes it hard to find out.
Midway:
No it is not.
It is exactly the same technique that is used to make individual bits change in shift registers. It is exactly the same technique that is used to make a digitalWrite() function work on individual pins of a port on the arduino.
It is a very simple concept which you seem to be making heavy weather out of.
The concept is you have a variable, you change only one bit in that variable and then you write the whole thing out to your peripheral / port / shift register. The bits you have not changed in the variable do not change in the output. The bits that you have changed in the variable change in the output.
Just to finish off this thread for anyone following it up later I have written a function that works exactly like the digitalWrite function but for a PCF8574. It is called digitalOutput and it takes the same parameters as digitalWrite.
// Output to I2C device as if it were a digitalWrite pin
void digitalOutput(byte pin, boolean level){
  static byte reg = 0xff;
  byte mask;
  mask = 1<< pin;
  if(level){
    reg |= mask;
  else {
    mask = ~mask; // invert mask
    reg &= mask;
  Wire.beginTransmission(PCF_address1);
  Wire.write(reg);                      // change bit
This code includes that function and also shows three ways you can use it.
Using a PCF8574
and controlling only one bit at a time
the function digitalOutput(pin, LEVEL) works just like the function
digitalWrite does for internal pins but for pins on the PCF8574
To drive an LED connect anode to +5V, cathode to resistor, resistor to
PCF8574 output pin.
By Mike Cook Feb 2013 - creative commons license share and share alike.
#define PCF_address1 0x38 // PCF8574AN, Address 0x38 with A0-A1-A2 pins grounded.
#include <Wire.h>
  Wire.begin();
  digitalOutput(0, HIGH); // initialise outputs
  static boolean flip = false;
  // examples of using digitalOutput
 // pin 0 toggling by direct HIGH and LOW
for(int i=0;i<9;i++){
  delay(200);
  digitalOutput(0, LOW);
  delay(200);
 // pin 1 toggling using the least significant bit of a variable to set HIGH and LOW
for(int i=0;i<8;i++){
  digitalOutput(1, i & 0x1);
  delay(200);
 // pin 2 toggling once per loop using a boolean variable to define HIGH and LOW
  digitalOutput(2, flip);
  flip = !flip; // invert the variable
  delay(300);
  byte mask;
  mask = 1<< pin;
  if(level){
    reg |= mask;
  else {
    reg &= mask;
Grumpy_Mike,
Never underestimate how people can misinterpret things.
I think using the term "pin" may not be clear to some folks
since the parameter is actually a bit number.
It might be a bit clearer for folks to change the names and/or terminology of your parameter
to clearly show that the parameter is bit numbers of the output port.
Or at least include some additional explanation that 0 is for controlling the pin P0,
1 is for the the pin P1, etc...
I've wrestled with a similar issue with an i2c lcd library.
In the case of the i2c to hd44780 adapters, people
would insert pin numbers of the PCF8574 or even the pin numbers of the hd44780 interface
rather than the actual bit numbers of the pcf8574 output register.
Once they finally "get it", it becomes clear, but often there is quite a bit of back and
forth and explanation needed until it finally sinks in.
--- bill
