Hello All,
I’m trying to use a PCF8575C port expander to drive 16 LED’s. I found this demo (which uses PCF8575)
that turns on each LED in series, but I’m unable to get it to work. This what I have at present :
(Arduino) PIN A4 → (PCF8575) PIN SDA
(Arduino) PIN A5 → (PCF8575) PIN SCL
(Arduino) PIN 5V → (PCF8575) PIN VCC
(Arduino) PIN GND → (PCF8575) PIN GND
(Arduino) PIN GND → (PCF8575) PIN A0, A1, A2
That’s the way it’s setup in the demo and in the makers blog http://www.lucadentella.it/2012/03/16/orologio-nixie-3-rtc-ed-expander/3/, yet I don’t get any response from the LED’s.
First off I was unable to get it to compile, after look at afew other code snippets I changed
Wire.write(low);
Wire.write(high);
to
Wire.send(low);
Wire.send(high);
and was able to get it to compile, but still not a blink from any of the LEDs.
The breakout board’s datasheet says Pin connections:
Breakout Board for PCF8575 I2C Expander
SDA to pin 4 on the analog header
SCL to pin 5 on the analog header
VCC to 5v
GND to GND
I/O pins need pull up resistors to VCC.
I didn’t use any resistors because the demo didn’t include them. What am I doing?
Sparkfun’s Breakout Board for PCF8575 I2C Expander has the PCF8575C IC
Description: Have you run out of I/O pins? This great IC allows the user to expand up to 16 I/O using only two I/O for control! The PCF8575C is controlled through an I2C interface and features 16-bits of quasi-bidirectional input/output pins. Checkout the datasheet for more info!
The bidirectional I
2C bus consists of the serial clock (SCL) and serial data (SDA) lines. Both lines must be
connected to a positive supply via a pullup resistor when connected to the output stages of a device
There is in fact a small difference in the schematic diagrams for PCF8575
and PCF8575C. The PCF8575C lacks the weak pull-up in the form of the 100 ?A
current source in the output I/Os. This is the reason that PCF8575's I/Os remain HIGH
after power-on and after being written HIGH. Without this current source, PCF8575C's
I/Os will be in high-impedance state after the initial strong pull-up transistor is OFF (it
is ON during the acknowledge phase)
So at the moment you can turn on the leds, even if they are very dim?
Did you connect them in "sink" mode (5v -> LED -> PCF8575 pin)? PCF8575 in source mode can't provide enough current...
thanks
Here's my wiring. LEDs flicker very dimly you almost can't even tell they're on at all.
(as wired lucadentella's demo) Think my next step is to add resistors to each i/o.
Here SDA and SCL are connected to Vcc via pullup resistors however all LEds remain HIGH, static not in sequence
