PCintPort Help for Project
Hello
I need to know what this snippet of the following code exactly does.
Also, please do tell me what does PCintPort and the doublle colon (::slight_smile: mean in an arduino code.
Thank You for your help.
#define RX_PINS_OFFSET 2
#define PIN_RX_THROTTLE 4
volatile int pwm_start_time[4];
uint8_t latest_interrupted_pin;
void initialize()
pinMode(PIN_RX_THROTTLE, INPUT); digitalWrite(PIN_RX_THROTTLE, HIGH);
PCintPort::attachInterrupt(PIN_RX_THROTTLE, &rising, RISING);
void rising()
latest_interrupted_pin=PCintPort::arduinoPin;
PCintPort::attachInterrupt(latest_interrupted_pin, &falling, FALLING);
pwm_start_time[latest_interrupted_pin-RX_PINS_OFFSET] = micros();
void falling() {
PCintPort::attachInterrupt(latest_interrupted_pin, &rising, RISING);
rx_values[latest_interrupted_pin-RX_PINS_OFFSET] = micros()-pwm_start_time[latest_interrupted_pin-RX_PINS_OFFSET];
PCintPort is the name of a class. The double colon is the scope resolution operator.
Here, it means call the (static) method, attachInterrupt(), of the PCintPort class.
Once you know that, the rest of the code is pretty straightforward. Each time there is a change detected on a pin, the other kind of change is looked for next. So, a FALLING edge will cause the interrupt handler trigger to be changed to RISING, and each time a RISING edge is detected, the interrupt handler trigger type will be changed to FALLING.
By the way, Arduino code is C++ code. The double colon is the C++ scope resolution operator as PaulS wrote.
