hi i am using a library called PCM, but my pin 11 is full so PCM.C
I changed the SpeakerPin and the Fast PWM in "void StartPlayBack" to 3, but I took 2 clicks from the buzzer and the sample did not come. what did i do wrong i troubleshoot but i found nothing broken
Changing "speakerPin = 11" to "speakerPin = 3" is not enough. You also have to change "OCR2A" to "OCR2B" and you have to turn on PWM on OC2B instead of OC2A. Change:
// Do non-inverting PWM on pin OC2A (p.155)
// On the Arduino this is pin 11.
TCCR2A = (TCCR2A | _BV(COM2A1)) & ~_BV(COM2A0);
TCCR2A &= ~(_BV(COM2B1) | _BV(COM2B0));
to:
// Do non-inverting PWM on pin OC2B (p.155)
// On the Arduino this is pin 3.
TCCR2A |= _BV(COM2B1); // Turn on COM2B1
TCCR2A &= ~_BV(COM2B0); // Turn off COM2B0
TCCR2A &= ~(_BV(COM2A1) | _BV(COM2A0));
Does the "playback" example that comes with the PCM library work on Pin 3 after you make the changes? If that works, the problem is probably caused by something else in your sketch.
