PDC non-blocking UART communication on Arduino Due
I am trying to use the PDC for UART communication on the Arduino Due. Why does Serial.begin() disable the PDC channel?
void UARTClass::init(const uint32_t dwBaudRate, const uint32_t modeReg)
  // Configure PMC
  pmc_enable_periph_clk( _dwId );
  // Disable PDC channel
  _pUart->UART_PTCR = UART_PTCR_RXTDIS | UART_PTCR_TXTDIS;
  // Reset and disable receiver and transmitter
  _pUart->UART_CR = UART_CR_RSTRX | UART_CR_RSTTX | UART_CR_RXDIS | UART_CR_TXDIS;
  // Configure mode
  _pUart->UART_MR = modeReg;
  // Configure baudrate (asynchronous, no oversampling)
  _pUart->UART_BRGR = (SystemCoreClock / dwBaudRate) >> 4;
  // Configure interrupts
  _pUart->UART_IDR = 0xFFFFFFFF;
  _pUart->UART_IER = UART_IER_RXRDY | UART_IER_OVRE | UART_IER_FRAME;
  // Enable UART interrupt in NVIC
  NVIC_EnableIRQ(_dwIrq);
  // Make sure both ring buffers are initialized back to empty.
  _rx_buffer->_iHead = _rx_buffer->_iTail = 0;
  _tx_buffer->_iHead = _tx_buffer->_iTail = 0;
  // Enable receiver and transmitter
  _pUart->UART_CR = UART_CR_RXEN | UART_CR_TXEN;
How do you try to use PDC?
That part of my project is working fine, so it's not super relevant to my question, which is mostly just out of interest/making sure there's not something critical to the functioning of Arduino's UART library that enabling the PDC channel interferes with. If you're interested in how I wrote my library, I can link you to a repo when I'm done with it.
yes, I'm definitely interested.
I tried to see when this line was added to the code, but it was already there in the very first commit. Maybe you could ask whoever committed or whose address is in the source file if there are older versions somewhere.
https://github.com/arduino/ArduinoCore-sam/commit/6067e3a03a1ad02113876e135b7b59755c8d9c98#diff-5b51fa30e15f709141b9359f4bcf05c457bfcd42bea64be003c00eb404725bfe
Have you contacted the guy?
Apologies for my very late response. I ended up resolving the interrupt issue by forking the Arduino framework into my own repo, editing the UART setup, and linking it to a PlatformIO project - Modifying clock configuration for Arduino Due - #2 by swallace23 - Development Platforms - PlatformIO Community.
PDC communication is very simple. The code is below. Please note that the register access code is silly - all of these registers are defined in CMSIS and could have been accessed without creating new pointers. Also note that this is only built for our requirements - where each data transmission never exceeds a known size of 294 bytes, so we simply memcpy all the data into a continuous array and give it to the PDC.
 * @file PDC.hpp
 * @brief Header file for the PDC library for *** Lab.
 * This library is used to manage UART communication on the Arduino Due using the Peripheral DMA Controller (PDC).
 * This allows for non-blocking communication, so that we can run other processes while sending out data.
 * Note for future developers - any data array sent through this library must be a global variable. If the variable goes out of scope before the transfer is
 * complete, the data will be lost.
 * Author: ***
 * Date: 2024-07-08
#ifndef PDC_HPP
#define PDC_HPP
#include <Arduino.h>
// Defining relevant UART registers
#define UART_BASE 0x400E0800
#define UART_PERIPH_TPR_ADDR (UART_BASE + 0x108) // Transmit pointer register
#define UART_PERIPH_TCR_ADDR (UART_BASE + 0x10C) // Transmit counter register
#define UART_PERIPH_TNPR_ADDR (UART_BASE + 0x118) // Transmit next pointer register
#define UART_PERIPH_TNCR_ADDR (UART_BASE + 0x11C) // Transmit next counter register
#define UART_PERIPH_PTCR_ADDR (UART_BASE + 0x120) // Peripheral transfer control register
#define UART_PERIPH_PTSR_ADDR (UART_BASE + 0x124) // Peripheral transfer status register
#define UART_SR (UART_BASE + 0x0014) // Status register
#define TXTEN (1<<8) //mask used to enable UART transmitter
#define TXBUFE (1<<11) //check if UART is ready
 * @brief Manages UART transmits through peripheral DMA controller (PDC).
class PDC {
private:
    // pointers to UART registers
    volatile uint32_t* const p_UART_TPR;
    volatile uint32_t* const p_UART_TCR;
    volatile uint32_t* const p_UART_TNPR;
    volatile uint32_t* const p_UART_TNCR;
    volatile uint32_t* const p_UART_PTCR;
    volatile uint32_t* const p_UART_PTSR;
    volatile uint32_t* const p_UART_SR;
    uint8_t backup_buffer[294];
public:
     * @brief Default constructor for the PDC class. Initializes all relevant register pointers
    PDC()
        : p_UART_TPR((uint32_t*)UART_PERIPH_TPR_ADDR),
          p_UART_TCR((uint32_t*)UART_PERIPH_TCR_ADDR),
          p_UART_TNPR((uint32_t*)UART_PERIPH_TNPR_ADDR),
          p_UART_TNCR((uint32_t*)UART_PERIPH_TNCR_ADDR),
          p_UART_PTCR((uint32_t*)UART_PERIPH_PTCR_ADDR),
          p_UART_PTSR((uint32_t*)UART_PERIPH_PTSR_ADDR),
          p_UART_SR((uint32_t*)UART_SR)
     * @brief Turns on PDC, waits until ready. Must be called AFTER Serial.begin() in setup().
    void init(){
    //enable pdc transmitter
    *p_UART_PTCR |= TXTEN;
    //wait until ready
    while(! PDC::is_on()){
     * @brief Adds data to the PDC buffer to be sent out through UART.
     * @tparam T - data type of buffer - either char pointer or integer array
     * @param buffer - pointer to data buffer. Note that it doesn't like pointer casts, so global pointers to sentinels must be used.
     * That's not an issue with Arduino's Serial library because it's blocking - avoiding that is the whole point of this.
     * @param size - size of buffer
     * This can also handle text in an ASCII readable format by using a char pointer:
     * @code
     * String message = "Hello World!";
     * uint8_t* p_message = (uint8_t*)message.c_str();
     * pdc.send(p_message, sizeof(message));
     * @endcode
     * But, Serial.print() is recommended for any debugging application to avoid global declarations.
     * Note for later - negative numbers are sent as two's complement. make sure *** parser is reading that correctly.
    template <typename T>
    void send(T* buffer, int size){
        //check if UART is ready for transmit
        if(*p_UART_SR & TXBUFE){
                //set buffer and size
                *(volatile uint32_t*)p_UART_TPR = (uint32_t)buffer;
                *p_UART_TCR = size;
        } else{
            memcpy(backup_buffer, buffer, size);
            enableUARTInterrupt();
            /* //wait until ready
            //digitalWrite(7, HIGH);
            while(!(*p_UART_SR & TXBUFE)){
            //digitalWrite(7, LOW);
            //same as above
                *p_UART_TCR = size; */
     * @brief Adds data to the backup PDC buffer. Identical to send().
    void send_next(T* buffer, int size){
                send(buffer, size);
            } else if (*p_UART_TNCR==0){
                *(volatile uint32_t*)p_UART_TNPR = (uint32_t)buffer;
                *p_UART_TNCR = size;
            else if (!(*p_UART_SR & TXBUFE)&&(*p_UART_TNCR!=1)){
                while(*p_UART_TNCR!=0){
            } else{
                send(buffer, size);
     * @brief Checks if the PDC and UART are on.
    bool is_on(){
        return (*p_UART_PTSR & (1<<8));
    void enableUARTInterrupt(){
        //enable UART interrupt
        NVIC_EnableIRQ(UART_IRQn);
        //interrupt on TXBUFE
        UART->UART_IER = UART_IER_TXBUFE;
        UART->UART_IDR = ~UART_IER_TXBUFE;
    void UART_Handler(){
        send(backup_buffer, sizeof(backup_buffer));
        NVIC_DisableIRQ(UART_IRQn);
#endif
  1. It's nice to have an example of DMA-based UART.
  2. But the normal Arduino code should also be "non-blocking", as long as output doesn't exceed buffering. (although it causes interrupts per character, rather than per buffer.)
What happens in your code when you make multiple calls to to send()? It looks like the first one will be output directly via DMA, the 2nd one will get memcpy()ed to the backup buffer, and the 3rd (and subsequent?) calls will also memcpy() to the backup buffer, overwriting the 2nd set of data.
Also, what happens if the DMA of the backup buffer has started, and you do another send() - won't that overwrite the buffer that is currently being transmitted?
Writing non-blocking code for a resource that is inherently much slower than the CPU is hard (technically rather impossible, I guess. Though you can cause out-of-memory crashes instead of blocking, if you try hard!)
