Hello everyone! I have added the firmata and firmware in the libraries folder (through right clicking on the arduino icon and "show package content".
Now, I have changed "Wboard.h" to "Arduino.h", but then this comes up.
Arduino:1.5.8 (Mac OS X), Board: "Arduino Uno"
/Applications/Arduino.app/Contents/Resources/Java/libraries/Firmata/Firmata.cpp: In function 'void sendValueAsTwo7bitBytes(int)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Firmata/Firmata.cpp:32:35: error: 'BYTE' was not declared in this scope
Serial.print(value & B01111111, BYTE); // LSB
/Applications/Arduino.app/Contents/Resources/Java/libraries/Firmata/Firmata.cpp: In function 'void startSysex()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Firmata/Firmata.cpp:38:29: error: 'BYTE' was not declared in this scope
Serial.print(START_SYSEX, BYTE);
/Applications/Arduino.app/Contents/Resources/Java/libraries/Firmata/Firmata.cpp: In function 'void endSysex()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Firmata/Firmata.cpp:43:27: error: 'BYTE' was not declared in this scope
Serial.print(END_SYSEX, BYTE);
/Applications/Arduino.app/Contents/Resources/Java/libraries/Firmata/Firmata.cpp: In member function 'void FirmataClass::printVersion()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Firmata/Firmata.cpp:82:32: error: 'BYTE' was not declared in this scope
Serial.print(REPORT_VERSION, BYTE);
/Applications/Arduino.app/Contents/Resources/Java/libraries/Firmata/Firmata.cpp: In member function 'void FirmataClass::printFirmwareVersion()':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Firmata/Firmata.cpp:104:35: error: 'BYTE' was not declared in this scope
Serial.print(REPORT_FIRMWARE, BYTE);
/Applications/Arduino.app/Contents/Resources/Java/libraries/Firmata/Firmata.cpp: In member function 'void FirmataClass::sendAnalog(byte, int)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Firmata/Firmata.cpp:270:46: error: 'BYTE' was not declared in this scope
Serial.print(ANALOG_MESSAGE | (pin & 0xF), BYTE);
/Applications/Arduino.app/Contents/Resources/Java/libraries/Firmata/Firmata.cpp: In member function 'void FirmataClass::sendDigitalPort(byte, int)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Firmata/Firmata.cpp:301:53: error: 'BYTE' was not declared in this scope
Serial.print(DIGITAL_MESSAGE | (portNumber & 0xF),BYTE);
/Applications/Arduino.app/Contents/Resources/Java/libraries/Firmata/Firmata.cpp: In member function 'void FirmataClass::sendSysex(byte, byte, byte*)':
/Applications/Arduino.app/Contents/Resources/Java/libraries/Firmata/Firmata.cpp:311:25: error: 'BYTE' was not declared in this scope
Serial.print(command, BYTE);
Fel vid kompilering.
enabled in File > Preferences.
OS.X 10.6.8
Arduino 1.5.8
Pduino-0.5.3
