Peace Love Arduino example from book by makezine
I am trying to figure out the last two examples in the book Getting Started with Arduino by Forest Mims
I just started chapter 6/Talking to the Cloud, and have run into a problem. Which gives an example of processing and Arduino talking to each other.
The problem I have run into is located in the processing sketch which I tried to make glow red, and bold on the code for quick reference and also quoted below
URL url = new URL(feed); // An object to represent the URL
  • the problem when I upload the sketch on processor it says
cannot find a class or type named "URL"
  • What does this mean? Can someone help me fix it?
The code for the processing sketch is located here
http://cdn.makezine.com/make/books/getstartedarduino/eg/Example_08A.txt
For convenience, I have posted this code below
// Example 08A: Arduino networked lamp
// parts of the code are inspired
// by a blog post by Tod E. Kurt (todbot.com)
// Copy and paste this example into an empty Processing sketch
import processing.serial.*;
String feed = "http://blog.makezine.com/index.xml";
int interval = 10;  // retrieve feed every 60 seconds;
int lastTime;       // the last time we fetched the content
int love    = 0;
int peace   = 0;
int arduino = 0;
int light = 0;  // light level measured by the lamp
Serial port;
color c;
String cs;
String buffer = ""; // Accumulates characters coming from Arduino
PFont font;
  size(640,480);
  frameRate(10);    // we don't need fast updates
  font = loadFont("HelveticaNeue-Bold-32.vlw");
  fill(255);
  textFont(font, 32);
  // IMPORTANT NOTE:
  // The first serial port retrieved by Serial.list()
  // should be your Arduino. If not, uncomment the next
  // line by deleting the // before it, and re-run the
  // sketch to see a list of serial ports. Then, change
  // the 0 in between [ and ] to the number of the port
  // that your Arduino is connected to.
  //println(Serial.list());
  String arduinoPort = Serial.list()[0];
  port = new Serial(this, arduinoPort, 9600); // connect to Arduino
  lastTime = 0;
  fetchData();
void draw() {
  background( c );
  int n = (interval - ((millis()-lastTime)/1000));
  // Build a colour based on the 3 values
  c = color(peace, love, arduino);
  cs = "#" + hex(c,6); // Prepare a string to be sent to Arduino
  text("Arduino Networked Lamp", 10,40);
  text("Reading feed:", 10, 100);
  text(feed, 10, 140);
  text("Next update in "+ n + " seconds",10,450);
  text("peace" ,10,200);
  text(" " + peace, 130, 200);
  rect(200,172, peace, 28);
  text("love ",10,240);
  text(" " + love, 130, 240);
  rect(200,212, love, 28);
  text("arduino ",10,280);
  text(" " + arduino, 130, 280);
  rect(200,252, arduino, 28);
  // write the colour string to the screen
  text("sending", 10, 340);
  text(cs, 200,340);
  text("light level", 10, 380);
  rect(200, 352,light/10.23,28); // this turns 1023 into 100
  if (n <= 0) {
    fetchData();
    lastTime = millis();
  port.write(cs); // send data to Arduino
  if (port.available() > 0) { // check if there is data waiting
    int inByte = port.read(); // read one byte
    if (inByte != 10) { // if byte is not newline
      buffer = buffer + char(inByte); // just add it to the buffer
    else {
      // newline reached, let's process the data
      if (buffer.length() > 1) { // make sure there is enough data
        // chop off the last character, it's a carriage return
        // (a carriage return is the character at the end of a
        // line of text)
        buffer = buffer.substring(0,buffer.length() -1);
        // turn the buffer from string into an integer number
        light = int(buffer);
        // clean the buffer for the next read cycle
        buffer = "";
        // We're likely falling behind in taking readings
        // from Arduino. So let's clear the backlog of
        // incoming sensor readings so the next reading is
        // up-to-date.
        port.clear();
void fetchData() {
  // we use these strings to parse the feed
  String data;
  String chunk;
  // zero the counters
  love    = 0;
  peace   = 0;
  arduino = 0;
  try {
[b][glow=red,2,300]URL url = new URL(feed);  // An object to represent the URL [/glow][/b]
    // prepare a connection
    URLConnection conn = url.openConnection();
    conn.connect(); // now connect to the Website
    // this is a bit of virtual plumbing as we connect
    // the data coming from the connection to a buffered
    // reader that reads the data one line at a time.
    BufferedReader in = new
      BufferedReader(new InputStreamReader(conn.getInputStream()));
    // read each line from the feed
    while ((data = in.readLine()) != null) {
      StringTokenizer st =
        new StringTokenizer(data,"\"<>,.()[] ");// break it down
      while (st.hasMoreTokens()) {
        // each chunk of data is made lowercase
        chunk= st.nextToken().toLowerCase() ;
        if (chunk.indexOf("love") >= 0 ) // found "love"?
          love++;    // increment love by 1
        if (chunk.indexOf("peace") >= 0)   // found "peace"?
          peace++;   // increment peace by 1
        if (chunk.indexOf("arduino") >= 0) // found "arduino"?
          arduino++; // increment arduino by 1
    // Set 64 to be the maximum number of references we care about.
    if (peace > 64)   peace = 64;
    if (love > 64)    love = 64;
    if (arduino > 64) arduino = 64;
    peace = peace * 4;     // multiply by 4 so that the max is 255,
    love = love * 4;       // which comes in handy when building a
    arduino = arduino * 4; // colour that is made of 4 bytes (ARGB)
  catch (Exception ex) { // If there was an error, stop the sketch
    ex.printStackTrace();
    System.out.println("ERROR: "+ex.getMessage());
The code for the arduino is located here http://cdn.makezine.com/make/books/getstartedarduino/eg/Example_08B.txt
and as I did previously, I copied the code below for convenience.
// Example 08B: Arduino Networked Lamp
// Copy and paste this example into an empty Arduino sketch
#define SENSOR 0
#define R_LED 9
#define G_LED 10
#define B_LED 11
#define BUTTON 12
int val = 0; // variable to store the value coming from the sensor
int btn = LOW;
int old_btn = LOW;
int state = 0;
char buffer[7] ;
int pointer = 0;
byte inByte = 0;
byte r = 0;
byte g = 0;
byte b = 0;
  Serial.begin(9600);  // open the serial port
  pinMode(BUTTON, INPUT);
  val = analogRead(SENSOR); // read the value from the sensor
  Serial.println(val);      // print the value to
                            // the serial port
  if (Serial.available() >0) {
    // read the incoming byte:
    inByte = Serial.read();
    // If the marker's found, next 6 characters are the colour
    if (inByte == '#') {
      while (pointer < 6) { // accumulate 6 chars
        buffer[pointer] = Serial.read(); // store in the buffer
        pointer++; // move the pointer forward by 1
      // now we have the 3 numbers stored as hex numbers
      // we need to decode them into 3 bytes r, g and b
      r = hex2dec(buffer[1]) + hex2dec(buffer[0]) * 16;
      g = hex2dec(buffer[3]) + hex2dec(buffer[2]) * 16;
      b = hex2dec(buffer[5]) + hex2dec(buffer[4]) * 16;
      pointer = 0; // reset the pointer so we can reuse the buffer
  btn = digitalRead(BUTTON); // read input value and store it
  // Check if there was a transition
  if ((btn == HIGH) && (old_btn == LOW)){
    state = 1 - state;
  old_btn = btn; // val is now old, let's store it
  if (state == 1) { // if the lamp is on
    analogWrite(R_LED, r);  // turn the leds on
    analogWrite(G_LED, g);  // at the colour
    analogWrite(B_LED, b);  // sent by the computer
    analogWrite(R_LED, 0);  // otherwise turn off
    analogWrite(G_LED, 0);
    analogWrite(B_LED, 0);
  delay(100);                // wait 100ms between each send
int hex2dec(byte c) { // converts one HEX character into a number
    if (c >= '0' && c <= '9') {
      return c - '0';
    } else if (c >= 'A' && c <= 'F') {
      return c - 'A' + 10;
                            // the serial port
Why?
You don't do anything with the value read from the analogue sensor.
Why?
I assure you I didn't write the code. I am new to programing, and am trying to learn TCP communication so I can get two arduinos to talk to each other wirelessly.
I tend to learn best by hands on experience, changing parts of the code and observing the outcomes. I have been following all the examples in the book, and in the pre-installed library, along with several YouTube videos. My favorite being the ones by Jeremy Blum https://www.youtube.com/user/sciguy14
The example I posted was written in the book "as is" and I am just trying to follow it, to figure out how the communication protocols work. The example UDP SendRecieveString example is broken as I pointed out in the threat WiFi UDP Send and Receive String Library Bug (need guidance) - #3 by Thomas499 - Programming Questions - Arduino Forum
The example UDP NTP works, but it is difficult to tinker with it (reverse engineer logic) when you don't have access to the server code that makes it work.
There's something about the two halves of that sentence that jars.
Seems you're not alone.
error with URL object - Processing Forum
Thanks, I didn't realize processing had a forum, like arduino does.
I imported import
java.net.URL;
and
import java.net.*;
as the website said to. This fixed that problem, but now I have an error on the line
that says
cannot find a class or type named "InputStreamReader"
The guy listed in the forum said
Re: Re: error with URL object
9 months ago
I ended up going with this approach once I realized what I was missing was in the Java API. Thanks for all your help
but I don't know what Java API is. I looked on the website that was provided in the prior post before he found the solution Java Platform SE 6 but I didn't find a reference to this Java API.... I don't understand how he fixed it
But now you do; this isn't an Arduino problem.
You are correct, I will sign up for the processing forum as well to figure this out.
Can anyone provide a reference to a working send/receive string example, a working two way Udp example, or preferably a two way TCP example that uses only the arduino programs for communications?
