Peculiarity with Switch Case Statement..
Hi there,
Arduino newbie here.. :)
I'm in the process of experimenting with a little vehicle, a couple of motors, 2 wheels, a sensor on the front for obstructions.. the next step up from Hello World I guess :)
I have the two motors working via a SN754410 Quad Half H-Bridge IC, 4 digital outputs driving it.. the distance sensor on the front is hooked up to an Analog Input..
I have the vehicle moving forward and stopping appropriately with the following code:
  float volts = analogRead(IRpin);
  if (volts > 200)
    digitalWrite(2, HIGH);
     digitalWrite(3, LOW);
     digitalWrite(4, HIGH);
     digitalWrite(5, LOW);
   digitalWrite(2, LOW);
   digitalWrite(4, LOW);
Seeking to start extending the functionality I moved the control of the vehicle out into a procedure.. one of the parameters of the procedure is the direction I want it to travel, there's a SwitchCase statement in the procedure to process it:
void RobotGo( int direction )
   switch( direction )
      case 3 :  //robotSTRAIGHT
      case 5 :  //robotSTOP
  if (volts > 200)
   RobotGo( 3 );
But this doesnt work.. the vehicle doesn't move.
With much experimenting I've found that introducing a delay within the switch statement causes it to work, you can see the change I made below:
   switch( direction )
          delay(50); //this pause makes it work!
Outputting some value to the serial port instead of using the Delay statement also works.. I'm quite puzzled the code works just fine if entirely contained with Void Loop.. but I move it out, and parameterize it and it fails..
Where have I gone wrong?
Duncan.
Duncan,
First of all, you don't need braces under each case. Second, one of the peculiarities of switch/case is that a case will fall through to the next case unless you end it with a break statement. You can use this to your advantage to do an "OR" type case statement:
switch (i)
case 1:
case 2:
  j = i;
case 3:
case 4:
  j = i / 2;
Here is a corrected version of your code:
   switch( direction )
Regards,
-Mike
Hi Mike..
Thanks so much for taking the time to respond.. Much appreciated! cant wait to get home and try it after work! :)
Cheers, Duncan.
