Hello all,
I am trying to obtain the RPM of the crank arms on a bicycle.
I have set it up on a stationary bicycle with two hall effect sensors in different positions on the rotation.
The idea is to use the first hall effect sensor (HE01) to measure the cadence and the second sensor (HE02) to confirm the sensors have been triggered.
The RPM is not being calculated properly and I cant not figure out why...
Anyone with any suggestions or critique would be greatly appreciated.
Thanks for taking the time to look at my problem.
If you need anymore information please let me know.
int RPM;
long newCtime = 0;
long newLastCt = 0;
long Ctime = 1000; // give this an initial value so that you can calculate debounceDelay
long lastCt = 0;
int HE01 = A0; // this is the analog pin
int HE02 = A1; // this is the analog pin
const int trigNum=840;
const int trigNum2=520;
boolean HE01trig = false;
// collect sensor data
int HE01val = analogRead(HE01);
int HE02val = analogRead(HE02);
// model data
if(HE01val > trigNum) {
newCtime = millis() - lastCt;
newLastCt = millis();
HE01trig = true;
if(HE01trig == true){
if(HE02val > trigNum2){
Ctime = newCtime;
lastCt = newLastCt;
RPM = 60000/Ctime;
HE01trig = false;
if(newCtime > Ctime){
Ctime = newCtime;
RPM = 60000/Ctime;
// update display
Serial.print("Cadence = ");
Serial.println(RPM);
