Percent of constant changing total value
Hello!
I have been working on a code for some time, and everything seems to be working, ecxept the part where my LED's should turn on.
I have 3 sensors that each has an LED.
What i want is having a LED turn on, when a specific sensor is 10% or over, the total value.
For example
Sensor1 = 10 Sensor2= 3 Sensor3= 30
Now total value is 43.
If Sensor1 gets over 20 of total value, LED1 should turn on.
Sensor1 is 23%.
Next reading shows
Sensor1 = 10 Sensor2= 3 Sensor3= 40
Now Sensor1 is 19%. and its LED should turn off..
I have tried some simple
sensor1/(sensor1+Sensor2+senor3)*100 > 20, digitalWrite (led1, high.)
but what it does is turning on when sensor1 is above 20 reading. not 20% What am i doing wrong?
Holse: I have tried some simple
Well, that isn't code, so you should post the actual code you're trying.
Integer arithmetic in C is not arithmetic, its integer arithmetic. 1/2 = 0 (ie division truncates to an integer result.
Perhaps you should try sensor1 * 100 / (sensor1+sensor2+sensor3) > 20
First of all I would do the calculations in stages as that makes debugging much easier
sensorTotal = sensor1 + sensor2 + sensor3
Then it is probably easier, with integer maths to invert the calculation - divide the big number by the smaller number
sensor1Part = sensorTotal / sensor1
Then you can do a test such as
if (sensor1Part <= 10) { // (anything over 10% will give a result less than 10)
…R
Thank you Robin2 and MarkT
I did as you for the easier debugging Robin2, and the calculations from MarkT, and now i am getting the results i want.
Thank you very much! ++
