Here is the full code, I will go into a bit of detail in the next post so you can have a chance to look at everything.
// Set up RTC
#include "Wire.h"
#define DS1307_I2C_ADDRESS 0x68
// Temperature Sensor
#include <avr/pgmspace.h>
#define THERM_PIN 0 // 10ktherm & 10k resistor as divider.
int fanPin = 3;
int fanVal;
int fanTemp = 300; // Temp Fans turn on
int offTemp = 600; // Temp LEDs turn off
// RTC variables
byte second, rtcMins, oldMins, rtcHrs, oldHrs, dayOfWeek, dayOfMonth, month, year, psecond;
// LED variables (Change to match your needs)
byte bluePins[] = {9, 10, 11}; // pwm pins for blues
byte whitePins[] = {5, 6}; // pwm pins for whites
byte blueChannels = 3; // how many PWMs for blues (count from above)
byte whiteChannels = 2; // how many PWMs for whites (count from above)
int startOffset = 500; // offset for start times
int colourOffset = 15; // offest for whites after blues start
[glow]byte blueLevel[] = {255, 255, 255}; // max intensity for Blue LED's
byte whiteLevel[] = {255, 255}; // max intensity for White LED's[/glow]
// Month Data for Start, Stop, Photo Period and Fade (based off of actual times, best not to change)
int daysInMonth[12] = {31, 29, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31}; //Days in each month
int minMinuteStart[12] = {310, 332, 348, 360, 372, 386, 394, 387, 364, 334, 307, 298}; //Minimum start times in each month
int maxMinuteStart[12] = {331, 347, 360, 372, 386, 394, 388, 365, 335, 308, 298, 309}; //Max start time in each month
int minMinuteFade[12] = {350, 342, 321, 291, 226, 173, 146, 110, 122, 139, 217, 282}; //Minimum fade time in each month
int maxMinuteFade[12] = {342, 321, 291, 226, 173, 146, 110, 122, 139, 217, 282, 350}; //Max fade time in each month
int minMinuteStop[12] = {1122, 1120, 1102, 1073, 1047, 1034, 1038, 1050, 1062, 1071, 1085, 1105}; //minimum stop times each month
int maxMinuteStop[12] = {1121, 1103, 1074, 1048, 1034, 1038, 1050, 1061, 1071, 1084, 1104, 1121}; //maximum stop times each month
// Weather variables
int weather = 1; // 0 off, 1 on
int clearDays[12] = {15, 12, 20, 23, 28, 37, 43, 48, 51, 41, 29, 23};
int cloudyDays[12] = {60, 61, 62, 60, 64, 63, 68, 66, 63, 54, 52, 53};
[glow]int clearDay = 0.25; // Max cloud value on clear day
int cloudyDay = 0.75; // Max cloud value on cloudy day
int normalDay = 0.5; // Max cloud value on normal day[/glow]
byte valueBlue[] = {0, 0, 0};
byte valueWhite[] = {0, 0};
byte value;
int day, fadeOn, fadeOff, time, pause, count, cloud;
long start, finish;
// Other variables.
int minCounter; // counter that resets at midnight. Don't change this.
long secCounter;
int fadeDuration; // minutes to fade - calculated by map above
int ledStartMins; // minute to start led's - calculated by map above
int ledStopMins; // minute to stop led's - calculated by map above
byte blueMax[] = {0, 0, 0}; // used for overtemp protection
byte whiteMax[] = {0, 0}; // used for overtemp protection
/****** LED Functions ******/
//function to set LED brightness according to time of day
byte setLed(
int mins, // current time in minutes
byte ledPin, // pin for this channel of LEDs
int start, // start time for this channel of LEDs
int fade, // fade duration for this channel of LEDs
int stop, // stop time for this channel of LEDs
byte ledMax, // max value for this channel of LEDs
long begin, // time cloud cycle begins in seconds
long secs, // current time in seconds
int on, // time for cloud to fade on in seconds
int off, // time for cloud to fade off in seconds
long time, // time of cloud
byte value // value for cloud
byte ledVal = 0;
if (mins <= start || mins >= stop) //this is when the LEDs are off, thus ledVal is 255;
ledVal = 0;
if (mins > start && mins <= start + fade) //this is sunrise
ledVal = map(mins, start, start + fade, 255, ledMax);
if (mins > start + fade && mins < stop - fade && weather == 1)
ledVal = ledMax;
if (count == 1){
if (secs >= begin && secs < begin + fadeOn)
ledVal = map(secs, begin, begin + on, ledMax, value);
if (secs >= begin + on && secs < begin + on + time)
ledVal = value;
if (secs >= begin + on + time && secs < begin + on + time + off)
ledVal = map(secs, begin + on + time, begin + on + time + off, value, ledMax);
if (secs >= begin + on + time + off)
ledVal = ledMax;
if (secs >= finish)
count = 0;
if (mins > start + fade && mins < stop - fade && weather == 0)
ledVal = ledMax;
if (mins < stop && mins >= stop - fade) //this is the sunset
ledVal = map(mins, stop - fade, stop, ledMax, 0);
analogWrite(ledPin, ledVal);
return ledVal;
/***** RTC Functions *******/
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return ( (val/16*10) + (val%16) );
// Gets the date and time from the ds1307
void getDateDs1307(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year)
Wire.beginTransmission(DS1307_I2C_ADDRESS);
Wire.send(0);
Wire.endTransmission();
Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
*second = bcdToDec(Wire.receive() & 0x7f);
*minute = bcdToDec(Wire.receive());
*hour = bcdToDec(Wire.receive() & 0x3f);
*dayOfWeek = bcdToDec(Wire.receive());
*dayOfMonth = bcdToDec(Wire.receive());
*month = bcdToDec(Wire.receive());
*year = bcdToDec(Wire.receive());
// init I2C
Serial.begin(57600);
Wire.begin();
randomSeed(analogRead(1));
