Percent timer by using arduino
Hello there.
I'm trying to make percent timer by using arduino. But can't find any example code on internet. I will control percentage by Blynk slider. Can anyone help me please?
Thanks in advance.
#define BLYNK_PRINT Serial
#define TINY_GSM_MODEM_SIM900
#include <SoftwareSerial.h>
#include <TinyGsmClient.h>
#include <BlynkSimpleTinyGSM.h>
#include <SimpleTimer.h>
BlynkTimer timer;
SoftwareSerial SerialAT(7, 8);
TinyGsm modem(SerialAT);
char apn = "internet";
char user = "";
char pass = "";
int startrelay = 9;
int startrelesi = 0;
bool startrelesiON;
unsigned long cycleTime = 60000;
unsigned long starttime ;
unsigned long onTime ;
unsigned long lastTime = 0;
float percent = 0;
char auth = "MyAuth";
BLYNK_WRITE(V3){ // START/STOP switch button in blynk app
startrelesi = param.asInt();
if (startrelesi== HIGH)
    Blynk.virtualWrite(V3, param.asInt());
else {
   digitalWrite(startrelay, LOW);
   Blynk.virtualWrite(V3, LOW);
BLYNK_WRITE(V6){ //slider for percentage adjusting from blynk app
percent = param.asFloat();
starttime = cycleTime * (1-(percent/100))-1000;
onTime = cycleTime * (percent/100);
Blynk.virtualWrite(V5, percent);
void start(){
      Blynk.virtualWrite(V3,startrelesi);
if(millis() - starttime < onTime)
startrelesiON = true;
startrelesiON = false;
if(millis() - starttime > cycleTime)
starttime += cycleTime; // starttime= starttime + cycleTime
if((startrelesiON == true) && (startrelesi == HIGH ) ){
digitalWrite(startrelay,HIGH);
digitalWrite(startrelay,LOW);
void setup(){
pinMode(12, OUTPUT);
digitalWrite(12,LOW);
digitalWrite(12,HIGH);
delay(2000);
SerialAT.begin(9600);
modem.restart();
Blynk.begin(auth, modem, apn, user, pass);
         pinMode(startrelay, OUTPUT);
           Blynk.virtualWrite(V6,0);// Slider in Blynk app
           Blynk.virtualWrite(V3,0); // toggle button in Blynk app
           Blynk.virtualWrite(V5,0);// labeled value in Blynk app
void loop(){
//CheckConnection();
timer.run();
Blynk.run();
start();
Forget about the percentage for now
Can you get a value from the Blynk slider to the Arduino and display it on the Serial monitor ?
I'm sorry for my bad English firstly.
Yes I can get the value. I want to make a center pivot controller. And I made it. I made percent timer too. The period is 60 seconds. When I choose 50% from the app relay pin has to be HIGH for 30 seconds and LOW for 30 seconds. But it doesn't work stable. Every time it cunts 60 seconds and plus 1 second LOW again. Totally 61 seconds. So I need true percent timer for my project.
Please post your code using code tags as described in How to get the best out of this forum
the code is below
BlynkTimer timer;
char apn[] = "internet";
char user[] = "";
char pass[] = "";
int startrelay = 9;
bool startrelesiON;
float percent = 0;
char auth[] = "MyAuth";
else {
void start(){
void setup(){
delay(2000);
modem.restart();
void loop(){
timer.run();
Blynk.run();
start();
Why did you take no notice of the advice to use code tags ?
post code using </>
