perchè non mi crea i nodi
scusatemi sono nuovo.
ho caricato questo sketck : garagedoor2, tenendo conto che ho dato ad arduino l’indirizzo 192.168.1.78 e al gateway 192.168.1.253, atteaverso la app, vedo che è online ma non mi crea nessun nodo.
perchè ? qualcuno ha qualche consiglio ?
grazie, Micos.
P.S.: ho provato sulla app get souliss nodes, ma niente .
// Configure the framework
#include “bconf/StandardArduino.h” // Use a standard Arduino
#include “conf/ethW5100.h” // Ethernet through Wiznet W5100
// Include framework code and libraries
#include <SPI.h>
#include “Souliss.h”
// Define the network configuration according to your router settings
uint8_t ip_address[4] = {192, 168, 1, 78};
uint8_t subnet_mask[4] = {255, 255, 255, 0};
uint8_t ip_gateway[4] = {192, 168, 1, 253};
#define Gateway_address 77
#define Peer_address 78
#define myvNet_address ip_address[3] // The last byte of the IP address (77) is also the vNet address
#define myvNet_subnet 0xFF00
#define myvNet_supern Gateway_address
#define GARAGEDOOR_NODE1 0
#define GARAGEDOOR_NODE2 0
#define GARAGELIGHT_NODE2 1
#define INPUTPIN_LIMIT_OPENING 2
#define INPUTPIN_LIMIT_CLOSING 4
#define OUTPUTPIN_LAMP 7
#define OUTPUTPIN_OPENING 8
#define OUTPUTPIN_CLOSING 9
Initialize();
// Set network parameters
Souliss_SetIPAddress(ip_address, subnet_mask, ip_gateway);
// Set the typical logic to handle the garage door and light
Set_GarageDoor (GARAGEDOOR_NODE2);
Set_SimpleLight(GARAGELIGHT_NODE2);
// Define inputs, outputs pins
pinMode(INPUTPIN_LIMIT_OPENING, INPUT); // Hardware pulldown required
pinMode(INPUTPIN_LIMIT_CLOSING, INPUT); // Hardware pulldown required
pinMode(OUTPUTPIN_LAMP, OUTPUT);
pinMode(OUTPUTPIN_OPENING, OUTPUT);
pinMode(OUTPUTPIN_CLOSING, OUTPUT);
// Here we start to play
EXECUTEFAST() {
UPDATEFAST();
// Execute every 510ms the logic, the command to open and close the garage door
// cames directly from SoulissApp or the push-button located on the other node
FAST_510ms() {
// Use Pin2 and Pin 4 as limit switches
DigIn(INPUTPIN_LIMIT_OPENING, Souliss_T2n_LimSwitch_Open, GARAGEDOOR_NODE2);
DigIn(INPUTPIN_LIMIT_CLOSING, Souliss_T2n_LimSwitch_Close, GARAGEDOOR_NODE2);
// Execute the logic for door or gate
Logic_GarageDoor(GARAGEDOOR_NODE1);
// Use Pin8 and Pin9 to control the open and close command through relays
DigOut(OUTPUTPIN_OPENING, Souliss_T2n_Coil_Open, GARAGEDOOR_NODE2);
DigOut(OUTPUTPIN_CLOSING, Souliss_T2n_Coil_Close, GARAGEDOOR_NODE2);
// If the door or gate is open / opening, switch ON the light
if((mOutput(GARAGEDOOR_NODE2) == Souliss_T2n_Coil_Open) || (mOutput(GARAGEDOOR_NODE2) == Souliss_T2n_LimSwitch_Open))
mInput(GARAGELIGHT_NODE2) = Souliss_T1n_OnCmd;
else if((mOutput(GARAGEDOOR_NODE2) == Souliss_T2n_Coil_Close) || (mOutput(GARAGEDOOR_NODE2) == Souliss_T2n_LimSwitch_Close))
mInput(GARAGELIGHT_NODE2) = Souliss_T1n_OffCmd;
// Execute the logic for light
Logic_SimpleLight(GARAGELIGHT_NODE2);
// Use Pin7 to control the light
DigOut(OUTPUTPIN_LAMP, Souliss_T1n_OnCoil, GARAGELIGHT_NODE2);
// Process the communication, this include the command that are coming from SoulissApp
// or from the push-button located on the other node
FAST_PeerComms();
EXECUTESLOW() {
UPDATESLOW();
SLOW_10s() {
// Time out commands if no limit switches are received
Timer_GarageDoor(GARAGEDOOR_NODE1);
Parli di una libreria proprietaria o comunque non ufficiale Arduino, non possiamo aiutarti se non ci spieghi per filo e per segno cosa vuoi fare e cosa stai adoperando.
Il codice devi racchiuderlo nei tag code, vedi sezione 7 del regolamento, spiega bene come fare ( pulsante </> ).
Altrimenti parte del codice può essere visualizzata male o mancare perchè interpretato come attributo del testo stesso.
Per problemi con Souliss chiedi direttamente all'autore
--> http://forum.arduino.cc/index.php?topic=80055.0
grazie proverò a chiederlo all'autore.
grazie a tutti per le risposte.
