Perfboard for a noob.
Hello Everyone,
I've just written this post, but my session timed out and I lost it. :0
Here we go again..
Anyways, I'm wiring up this circuit, with 2 shift registers (I may expand upto 5) and 4 displays (may expand upto 9).
I need 8 common buses for the 7 display segments, and the decimal point. These will go to all of the displays.
I also need 2 common buses for Shift Clock and Latch Clock, which will go to all of the shift registers.
There's 4 Common Cathodes per display, that go to the shift registers.
I've got a sheet of blank perfboard, and a sheet with individual solder pads.
What's the best way to make buses on perfboard? Also, any tips laying this circuit out before I start soldering?
I've also got IC sockets for the shift registers and headers for the displays, so I don't burn anything out with my noobie soldering skills.
Thanks in advanced!
Download the software from expresspb.com, really easy to use the pcb software to layout the chips and play with placement.
Bunch of "island of holes" boards here, copy the dimensions into expresspcb and start working the layout.
http://www.futurlec.com/ProtoBoards.shtml#PRBRDLG
I find wirewrapping digital circuits with lots of connections is a great way to go as well. Line up the parts with shared connections, and just go pin to pin to pin, highlighting them on a paper schematic as you go.
Socket pins like these for each chip
http://www.king-cart.com/cgi-bin/cart.cgi?store=phoenixent&product_name=HWS15765
and an Oki Industries wirewrap tool
My tool of choice is the WSU-30 & 30 guage wirewrap wire.
http://www.jonard.com/jonard-ecommerce/control/product/~category_id=HAND_WRAP_TOOLS_1/~product_id=10021
but others have had okay experience with the Radio Shack version as well. I find it clunky myself.
Once you have a layout you like, solder the end pins down on a socket, maybe 1 in the middle if it is a long strip.
Connect all the grounds, and power pins, using mostly a star configuration.
Then add the signal connections.
I like 3 different colors if possible, power, ground, signal.
Don't forget 0.1uF decoupling caps on all the ICs between power & ground.
CrossRoads:
I'm most concerned with setting up buses and wiring everything. Can expresspb do that?
CrossRoads:
Looks like an interesting prospect. I've got all the parts right now to solder though. So I might as well go that route.
Don't be, just treat them as point to point connections there is nothing special about it.
Lay out the major components and if the strips make the connections then it's a bonus, otherwise wire up the connections point to point with wires.
Grumpy_Mike:
So I solder the components to the board first, and then heat that solder up again and attach the wires? What gauge is usually used?
What I do is to fix the IC socket by just soldering opposite corners. Then solder it when I do the wires. However if you need to add a wire then you can do by remelting the joints.
I leave two holes free to each side of every IC connector, that way you can always track back and add another wire to any node. I use wire as thin as you can get 0.2mm is good. For a prototype board I use solid strand wire but if a cable has to flex at all then I use multi stranded.
As an alternative to perfboard you can use stripboard, which has buses already. There are programs such as VeroDes that you can use to design the layout.
wire wrap wire avail in a variety of colors is thin flexible and strips easily. Who says you can't solder it! Use a 25W or less iron until you get really good at soldering. Solder in a moderate temp room ie 70ish F, have a clean damp rubber sponge, not an acrylic sponge, the latter will melt thus defeating the purpose of dabbing the iron tip.
@dc42
Thank for the tip. I search for "VeroDes", and I have download the instalation program. A "vero" can be easilly made by making a DYI PCB in a "vero" design.
@Panici
I know one thing... it is not going to be an easy job to solder/wire. You just simply need to be patience and methodical about it.
CrossRoads:
Easier to use then EagleCAD? I've started messing around with it EagleCAD a little.
Grumpy_Mike:
Gotcha.
So I should grab some 30awg wire then? Anyone have a good source for cheap wire? I'd like to get a bunch of different colors, and I don't need that much length of each.
For layouts of hand assembled boards, I think yes. Count the number of holes you have available and drag the corners to match.
Drop in the parts for the sizes you will use, put the pins on the dots. No need to hunt all thru eagle to find the right part - just drop in a generic package. Can have the parts layed out in no time, print it, and start wiring.
CrossRoads:
Ok, i'll give it a shot!
Hmm, never tried soldering 30 guage, only wirewrapped that small. Not sure how the insulation would hold up with heat when there is so little of it.
This might work, look around see if you have similar handy.
http://www.dipmicro.com/store/WIRE24
For small wire like that you are probably better off getting stranded wire not solid, solid wire has a tendency to break at the ends easily, and its a pain to have to resolder it back on
stranded is more flexible which I find easier to route around, and it wont break so long as you strip it fine without nicking the wires,
CrossRoads:
I've been soldering wire-wrap wire for decades, it's my standard wiring method using hole per pad protoboards. The insulation is very strong and holds up well to the soldering heat. 30 gage wire has such small mass so it takes very little time to solder to a pad. The biggest thing about using wire wrap wire is to have a purpose designed wire stripper or you will have problems with nicked wires that can easily break off after soldering.
Lefty
After I discovered wirewrapping, I never went back to point to point wiring. Wirewrap is great for digital, and twisted-pair/coax for analog signals.
CrossRoads:
I too did a lot of building using wirewrap sockets in the past. However now a days the prices of wirewrap sockets are pretty dear and not real compatible with 'hobby budgets'. At one time I use to be able to buy large surplus logic boards that might contain hundreds of 14 and 16 pin WW sockets for a song, but haven't seen such offering in years.
Lefty
I don't use sockets either. I buy strips of pins like this and cut off what I need.
Works great for a Promini, which is too wide for a standard 0.6" wide 24 pin socket.
5 cents a pin that way, cheaper than a socket.
CrossRoads:
That is a great method, I guess I just never came up with a source for 'strip pins'.
