Performance digitalRead(), digitalWrite()
Hi all,
which is the best option?
float temp = ReadTemp();
if (temp > 30)
//check pin state
if (digitalRead(43) == LOW)
digitalWrite(43, HIGH);
//or simply always set pin to HIGH
Thanks
Zdenal
if (temp > 30)
      //check pin state
      digitalWrite(43, LOW);
Otherwise, how will it go low?
// ... simply always set pin to HIGH
CrossRoads:
if (temp > 30)
      //check pin state
It is only example / snippet :slight_smile:
Simply inverting a pin?
digitalWrite (43, ! digitalRead (43)) ;
Though one would normally store the pin state in a variable:
  pin_state = !pin_state ; // invert
  digitalWrite (43, pin_state) ; // output
If you call digitalRead it takes more time and you are sensitive to the pin being shorted out
causing different behaviour.
Why don't you write a small test code that e.g. loops thousand times and measure the durations for the different approaches?
	if ( temp > 30 )
#f 0
		// variable time to set as we first check it's value and only set it if
		// it's not high, but why bother as if it is LOW then set it to HIGH and
		// if it's already HIGH what difference would it make to set it HIGH
		// regardless ...
		if ( digitalRead(43) == LOW )
#else
		// ... const time to set ...
#endif
