Performance question: 4 versions of same sketch
Hi all,
I would be interested to gather any insights into this.
I have 4 versions of the same sketch here. Each has the same amount of bit-wise processing to be performed, which includes lots of shifts and logical AND/OR etc. The application is running Conway’s Game Of Life on a 128x192 grid and using the TVOut library to display the results on a Nano 3.
The difference between the 4 sketches is the number of bits/cells processed in parallel: 8 bits, 16 bits, 32 bits or 64 bits at a time.
The results are:
Version Sketch size Generations per second
8 bit 8K 10
16 bit 9K 15
32 bit 10K 15
64 bit 18K 3
The surprise for me was how poor the 64 bit version performs, and its size.
8 bit sketch:
// Conway's Game Of Life 128x96 using TVout
// P.Beard
// March 2013
#include <TVout.h>
#define matWidth 16
#define matHeight 96
TVout TV;
unsigned char * myScreen;
  TV.begin(PAL, matWidth * 8, matHeight);
  myScreen = (unsigned char *) TV.screen;
  randomSeed(analogRead(0));
  randomiseMatrix();
  Serial.begin(38400);
  unsigned long start = millis();
  for (int i = 1; i <= 10; i++) {
    generateMatrix();
    digitalWrite(13, !digitalRead(13));
  Serial.print( 100000UL / (millis() - start));
  Serial.println( " Gen per 10s");
unsigned int swapBytes(unsigned int x) {
  return x;
void randomiseMatrix() {
  //Set up initial cells in matrix
  for (int r = 0; r < matHeight; r++) {
    for (int c = 0; c < matWidth; c++) {
      myScreen[r * matWidth + c] = random(0xff);
void injectGlider() {
  byte col = random(matWidth);
  byte row = random(matHeight);
  myScreen[(row+0) * matWidth + col] |= B0000111;
  myScreen[(row+1) * matWidth + col] |= B0000001;
  myScreen[(row+2) * matWidth + col] |= B0000010;
void generateMatrix() {
  //Variables holding data on neighbouring cells
  unsigned char NeighbourN[matWidth], NeighbourNW[matWidth], NeighbourNE[matWidth], CurrCells[matWidth], NeighbourW[matWidth];
  unsigned char NeighbourE[matWidth], NeighbourS[matWidth], NeighbourSW[matWidth], NeighbourSE[matWidth], firstRow[matWidth];
  unsigned char tot1, tot2, tot4, carry, NewCells;
  int changes = 0; // counts the changes in the matrix
  static int prevChanges = 256; // counts the changes in the matrix on prev generation
  static int staleCount = 0; // counts the consecutive occurrances of the same number of changes in the matrix
  //set up N, NW, NE, W & E neighbour data
  //also take a copy of the first row data for use later when calculating last row
  for (byte b = 0; b < matWidth; b++) {
    NeighbourN[b] = swapBytes(myScreen[(matHeight-1) * matWidth + b]);
    firstRow[b] = CurrCells[b] = swapBytes(myScreen[b]);
  carry = NeighbourN[matWidth-1];
  for (char b = 0; b < matWidth; b++) {
    NewCells = NeighbourN[b];
    NeighbourNW[b] = NewCells >> 1 | carry << 7;
    carry = NewCells;
  carry = NeighbourN[0];
  for (char b = matWidth-1; b >= 0; b--) {
    NeighbourNE[b] = NewCells << 1 | carry >> 7;
    carry = NewCells;
  carry = CurrCells[matWidth-1];
    NewCells = CurrCells[b];
    NeighbourW[b] = NewCells >> 1 | carry << 7;
    carry = NewCells;
  carry = CurrCells[0];
    NeighbourE[b] = NewCells << 1 | carry >> 7;
    carry = NewCells;
  //Process each row of the matrix
  for (byte row = 0; row < matHeight; row++) {
    //Pick up new S, SW & SE neighbours
    if (row < matHeight - 1) {
        NeighbourS[b] = swapBytes(myScreen[(row+1) * matWidth + b]);
    else {
        NeighbourS[b] = firstRow[b];
    carry = NeighbourS[matWidth-1];
      NewCells = NeighbourS[b];
      NeighbourSW[b] = NewCells >> 1 | carry << 7;
      carry = NewCells;
    carry = NeighbourS[0];
      NeighbourSE[b] = NewCells << 1 | carry >> 7;
      carry = NewCells;
       //Count the live neighbours (in parallel) for the current row of cells
      //However, if total goes over 3, we don't care (see below), so counting stops at 4
      tot1 = NeighbourN[b];
      tot2 = tot1 & NeighbourNW[b]; tot1 = tot1 ^ NeighbourNW[b];
      carry = tot1 & NeighbourNE[b]; tot1 = tot1 ^ NeighbourNE[b]; tot4 = tot2 & carry; tot2 = tot2 ^ carry;
      carry = tot1 & NeighbourW[b]; tot1 = tot1 ^ NeighbourW[b]; tot4 = tot2 & carry | tot4; tot2 = tot2 ^ carry;
      carry = tot1 & NeighbourE[b]; tot1 = tot1 ^ NeighbourE[b]; tot4 = tot2 & carry | tot4; tot2 = tot2 ^ carry;
      carry = tot1 & NeighbourS[b]; tot1 = tot1 ^ NeighbourS[b]; tot4 = tot2 & carry | tot4; tot2 = tot2 ^ carry;
      carry = tot1 & NeighbourSW[b]; tot1 = tot1 ^ NeighbourSW[b]; tot4 = tot2 & carry | tot4; tot2 = tot2 ^ carry;
      carry = tot1 & NeighbourSE[b]; tot1 = tot1 ^ NeighbourSE[b]; tot4 = tot2 & carry | tot4; tot2 = tot2 ^ carry;
      //Calculate the updated cells:
      // <2 or >3 neighbours, cell dies
      // =2 neighbours, cell continues to live
      // =3 neighbours, new cell born
      NewCells = (CurrCells[b] | tot1) & tot2 & ~ tot4;
      //Have any cells changed?
      if (NewCells != CurrCells[b]) {
        myScreen[row * matWidth + b] = swapBytes(NewCells);
        //Count the change for "stale" test
        changes++;
      //Current cells (before update), E , W, SE, SW and S neighbours become
      //new N, NW, NE, E, W neighbours and current cells for next loop
      NeighbourN[b] = CurrCells[b];
      NeighbourNW[b] = NeighbourW[b];
      NeighbourNE[b] = NeighbourE[b];
      NeighbourE[b] = NeighbourSE[b];
      NeighbourW[b] = NeighbourSW[b];
      CurrCells[b] = NeighbourS[b];
    } //next col
  } //next row
  if (changes != prevChanges) staleCount = 0; else staleCount++; //Detect "stale" matrix
  if (staleCount > 32) injectGlider(); //Inject a glider
  prevChanges = changes;
16 bit sketch:
// P.Beard
// March 2013
#include <TVout.h>
#define matWidth 8
TVout TV;
unsigned int * myScreen;
  TV.begin(PAL, matWidth * 16, matHeight);
  myScreen = (unsigned int *) TV.screen;
  randomiseMatrix();
    generateMatrix();
  return ((x & 0x00ffU) << 8) | ((x & 0xff00U) >> 8);
      myScreen[r * matWidth + c] = random(0xffff);
  unsigned int NeighbourN[matWidth], NeighbourNW[matWidth], NeighbourNE[matWidth], CurrCells[matWidth], NeighbourW[matWidth];
  unsigned int NeighbourE[matWidth], NeighbourS[matWidth], NeighbourSW[matWidth], NeighbourSE[matWidth], firstRow[matWidth];
  unsigned int tot1, tot2, tot4, carry, NewCells;
    NeighbourNW[b] = NewCells >> 1 | carry << 15;
    carry = NewCells;
    NeighbourNE[b] = NewCells << 1 | carry >> 15;
    carry = NewCells;
    NeighbourW[b] = NewCells >> 1 | carry << 15;
    carry = NewCells;
    NeighbourE[b] = NewCells << 1 | carry >> 15;
    carry = NewCells;
    else {
      NeighbourSW[b] = NewCells >> 1 | carry << 15;
      carry = NewCells;
      NeighbourSE[b] = NewCells << 1 | carry >> 15;
      carry = NewCells;
        changes++;
    } //next col
  } //next row
32 bit sketch:
// P.Beard
// March 2013
#include <TVout.h>
#define matWidth 4
TVout TV;
unsigned long * myScreen;
  TV.begin(PAL, matWidth * 32, matHeight);
  myScreen = (unsigned long *) TV.screen;
  randomiseMatrix();
    generateMatrix();
unsigned long swapBytes(unsigned long x) {
  return ((x & 0x000000ffUL) << 24) | ((x & 0x0000ff00UL) << 8) | ((x & 0x00ff0000UL) >> 8) | ((x & 0xff000000UL) >> 24);
      myScreen[r * matWidth + c] = random(0xffff) << 16 | random(0xffff);
  unsigned long NeighbourN[matWidth], NeighbourNW[matWidth], NeighbourNE[matWidth], CurrCells[matWidth], NeighbourW[matWidth];
  unsigned long NeighbourE[matWidth], NeighbourS[matWidth], NeighbourSW[matWidth], NeighbourSE[matWidth], firstRow[matWidth];
  unsigned long tot1, tot2, tot4, carry, NewCells;
    NeighbourNW[b] = NewCells >> 1 | carry << 31;
    carry = NewCells;
    NeighbourNE[b] = NewCells << 1 | carry >> 31;
    carry = NewCells;
    NeighbourW[b] = NewCells >> 1 | carry << 31;
    carry = NewCells;
    NeighbourE[b] = NewCells << 1 | carry >> 31;
    carry = NewCells;
    else {
      NeighbourSW[b] = NewCells >> 1 | carry << 31;
      carry = NewCells;
      NeighbourSE[b] = NewCells << 1 | carry >> 31;
      carry = NewCells;
        changes++;
    } //next col
  } //next row
64 bit version:
// P.Beard
// March 2013
#include <TVout.h>
#define matWidth 2
TVout TV;
unsigned long long * myScreen;
  TV.begin(PAL, matWidth * 64, matHeight);
  myScreen = (unsigned long long *) TV.screen;
  randomiseMatrix();
    generateMatrix();
unsigned long long swapBytes(unsigned long long x) {
  return ((x & 0x00000000000000ffULL) << 48) |
         ((x & 0x000000000000ff00ULL) << 32) |
         ((x & 0x0000000000ff0000ULL) << 16) |
         ((x & 0x00000000ff000000ULL) << 8) |
         ((x & 0x000000ff00000000ULL) >> 8) |
         ((x & 0x0000ff0000000000ULL) >> 16) |
         ((x & 0x00ff000000000000ULL) >> 32) |
         ((x & 0xff00000000000000ULL) >> 48);
  unsigned long long NeighbourN[matWidth], NeighbourNW[matWidth], NeighbourNE[matWidth], CurrCells[matWidth], NeighbourW[matWidth];
  unsigned long long NeighbourE[matWidth], NeighbourS[matWidth], NeighbourSW[matWidth], NeighbourSE[matWidth], firstRow[matWidth];
  unsigned long long tot1, tot2, tot4, carry, NewCells;
    carry = NewCells;
    carry = NewCells;
    carry = NewCells;
    carry = NewCells;
    else {
      carry = NewCells;
      carry = NewCells;
        changes++;
    } //next col
  } //next row
I’m not sure I have the stamina to study one of your sketches, never mind four.
Perhaps you can write a short sketch that illustrates the differences?
…R
Hmmm... can't really blame you Robin. I'll have a think about something else simpler. But in the meantime, if you read one of the sketches, you have pretty much read them all. The only significant differences are the size of variables (unsigned char, int, long, long long) and the swapbytes () function.
On an eight bit processor, that's a surprise?
Really?
I'm surprised it's only three times slower.
AWOL:
Well, the 16 bit version is faster than the 8 bit, on an eight bit processor, so its not that simple. The 32 bit is about the same speed as the 16 bit.
So there are multiple factors affecting the speed, and program size. Some factors improve the speed with increasing variable size, other factors have the opposite effect. I'd just like to understand them better.
You’re doing lots of large bitshifts in the 64-bit version. On an 8-bit processor without many registers that isn’t likely to optimise very well.
Thanks Peter, that makes sense: in the 8 bit version, maybe the compiler can't find ways to use as many registers as it can in the 16/32 bit versions, hence its a little slower. In the 64 bit version, it doesn't have enough registers and has to start using stack/heap memory to hold partial results data temporarily, casuing a dramatic slowdown. All those extra memory operations could explain the sudden increase in program size too.
Of course, this result is going to be unique to the ATmega328. Other 8 bit processors might have more register space and could deal better with the 64 bit operations. Others with less register space might not cope as well with the 32 bit version. Certainly a 32 bit processor like Due/Teensy 3/Spark Core/RPi would be a very different story.
Thanks!
Paul
